annoying gas light.
Old Mar 20, 2006 | 02:14 PM
HXvtec's Avatar
Default annoying gas light.
so for some reason my gas light only comes on when i absolutely need gas. now it never used to be like this. is there anyway i can adjust or something?
Old Mar 20, 2006 | 02:16 PM
Blazin Civic's Avatar
Default Re: annoying gas light. (HXvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec &raquo;</TD></TR><TR><TD CLASS="quote">so for some reason my gas light only comes on when i absolutely need gas. </TD></TR></TABLE>
Thats what it is supposed to do...you aren't supposed to let a tank run that dry.
Old Mar 20, 2006 | 02:22 PM
professor poon's Avatar
ugh...
JDMFreak's Avatar
Default Re: annoying gas light. (Blazin Civic)
i remembering reading somewhere that you can adjust your gas light somewhere...i have to check my helms again...i will look for it after school
Old Mar 20, 2006 | 03:27 PM
kaoss_11's Avatar
B A N N E D
wtf? Do you know thats its bad to run your fuel pump on low gas. i know it strains it or doesnt make it work properly. I thought thats what fuel light was for
Old Mar 20, 2006 | 03:37 PM
fmrprojects's Avatar
Default Re: (kaoss_11)
wtf. its bad to let the tank go empty. you atart sucking up alll the **** on the bottom of the tank and it cloggs up filters, injectors
Old Mar 20, 2006 | 03:39 PM
HXvtec's Avatar
yes i know it is bad but the thing is it used to come on when i had 1/4 of a tank left. now when it comes on i better get to a gas station before i stall.
Old Mar 20, 2006 | 05:23 PM
kaoss_11's Avatar
B A N N E D
ok i see the issue now.
Old Mar 20, 2006 | 05:33 PM
EckoTech
Guest
Posts: n/a
It could be that your needle got off track or something... Like the needle sits in a different spot now, and it seems like your gas light is now coming on at a different time. ****, I don't know if that made sense or not... someone get what i'm trying to say?
Old Mar 20, 2006 | 07:47 PM
HXvtec's Avatar
Default Re: (EckoTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EckoTech &raquo;</TD></TR><TR><TD CLASS="quote">It could be that your needle got off track or something... Like the needle sits in a different spot now, and it seems like your gas light is now coming on at a different time. ****, I don't know if that made sense or not... someone get what i'm trying to say? </TD></TR></TABLE>
i get it thanks.
Old Mar 20, 2006 | 07:50 PM
98_4drCivic's Avatar
it sounds to me like its working properly
Old Mar 20, 2006 | 08:47 PM
egcivic's Avatar
Default Re: (98_4drCivic)
umm yea thats what its supossed to do
i dont think quarter tank calls for a gas light.. and honestly jsut watch your gas gauge
its not that hard. and if you realli dont trust ur gas gauge then calculate how much gas u normally get to a tank and go off ur odometer.
Old Mar 20, 2006 | 08:54 PM
Paprika's Avatar
i don't even have a gas light
Old Mar 20, 2006 | 08:56 PM
silentblackhat's Avatar
i never even let my tank run that low. its bad for the fuelpump. also i never let it run that low incase somethin happens like being stuck in traffic and not being able to get to a gas station for a while
Old Mar 20, 2006 | 09:47 PM
EckoTech
Guest
Posts: n/a
Default Re: annoying gas light. (silentblackhat)
yeah I have a really bad habit of letting it run till..well.. it barely starts, lol. I dont have a gas light, but thats def not the problem...
Old Mar 21, 2006 | 07:14 PM
Gadget's Avatar
Default Re: annoying gas light. (EckoTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EckoTech &raquo;</TD></TR><TR><TD CLASS="quote">wtf. its bad to let the tank go empty. you atart sucking up alll the **** on the bottom of the tank and it cloggs up filters, injectors</TD></TR></TABLE>
That's an urban myth.. It's all bullshit.. Where do you suppose the inlet to your pump is located? At the top of the tank where there is NO GAS??? Haha.. use your head before you say something.. The pump lives on the bottom of your tank.. end of story...
Further more..
If you are really worried about it, check it out.. get a 5 gallon can of gas.. fil it up.. when your light comes on, throw the tank of gas in the back of your car and go for a drive and see how long you can drive before it starts to sputter.. this will give you an idea of what your range is.. Now all you have to do is take the gas can, pour it into your tank and find a gas station.. Easy as that..
goheel
Mar 8, 2007 09:34 PM
emegge
Jul 23, 2006 10:51 AM
hotsuma23
Oct 4, 2004 01:36 PM
ludenutz
Jan 23, 2004 10:44 AM
ALLMOTOR18
Dec 2, 2002 02:11 PM
