Removing the rotor, tune up (????????)
Quick question, i'm doing a tune-up and I can't remove the rotor after the distributor cap. How do I remove it? Is there a bolt/screw to untwist?
It's getting dark, need help fast!!!
bump the ignition a couple times till you see the screw in the rotor.
get a screw drive that fits the screw very well and unscrew it.
if you dont get a screw drive that fits it nicly they it might strip it.
jus apply alot of presure downward on the screw and you will be fine
in addition to /\ this info, i use a flat blade screwdriver and wedge it b/t the rotor screw and the rotor body to break the "weld" that has occurred because of heat and usage. it helps to remove the screw.
zairas
Oct 19, 2009 03:08 PM
97SS
May 12, 2009 10:07 PM
Tealeg88
10
Jan 15, 2006 08:43 PM
