04 Alignment Kit errr
Old Mar 20, 2006 | 01:30 PM
msedacca's Avatar
Default 04 Alignment Kit errr
So, after running my tires on a bent camber for 2 months, finally invested in a Progress alignment kit. So, they showed up in the mail, and I get 2 pivot bearings, and 2 control arms. So, I thought, wtf? Shouldn't there be 2 more of each? So I called up the shop that I bought them from and they said that that I received the correct amount of parts. Does this make sense if I purchased a 4 wheel kit and I'm looking for a 4 wheel adjustment? Can someone explain this? Thanks
Old Mar 20, 2006 | 02:52 PM
BLKFLSH's Avatar
Default Re: 04 Alignment Kit errr (msedacca)
Hahahahahaha. You bring it on your self. Now I know why Lions eat there young.
Old Mar 20, 2006 | 04:24 PM
msedacca's Avatar
Default Re: 04 Alignment Kit errr (BLKFLSH)
Seriously, shut the expletive up, i'm not asking for your wise *** comment when I'm looking for some help so I can fix my car. If you don't have something to help, then get the expletive out.
Old Mar 22, 2006 | 01:01 AM
MauiWowwee's Avatar
correct me if i'm wrong, don't the 98+ accords aftermarket camber kits require balljoints and yes, control arms? so from your info, i think you got the required pieces. when i searched the progress site, it showed the ball joints, one per side, and the control arms, again one per side.
the ingalls kit is different in the rear.
Old Mar 22, 2006 | 02:30 AM
msedacca's Avatar
Default Re: (MauiWowwee)
ok, thanks for your help.
Old Mar 22, 2006 | 04:44 PM
msedacca's Avatar
Default Re: (msedacca)
FYI Update:
I was wrong, you were correct, the control arms are for the front wheels, pivot bushings are for the rear wheels. Camber fixed (caster is still off unfortunately, can't fix it), car handles much better.
adam squared
Jan 18, 2010 07:27 PM
d0ugch0i
Suspension & Brakes
Oct 22, 2007 04:08 PM
6doorsentra
19
Jul 10, 2007 11:11 AM
WhOaiTzJapE
Nov 27, 2004 10:28 AM
MysteryWagon
Apr 29, 2002 09:20 AM
