Rear Fenders
Old Mar 20, 2006 | 01:15 PM
carbonk20's Avatar
Default Rear Fenders
Has anyone installed rear replacement fenders on their eg hatch? Pain in the butt? Results, pics?
Old Mar 20, 2006 | 01:28 PM
93CharcoalHatch's Avatar
Default Re: Rear Fenders (carbonk20)
are you talking about the pieces to fix rust ? if so i would like to know some stuff about it too because i need to do it i have lots of rust back there
Old Mar 20, 2006 | 01:39 PM
CRR 2's Avatar
well you can either fill it in with bondo? Or you can cut the rusted area out find a donor car that has no rust and cut that out weld new ones in grind then paint Bondo will crack.
Old Mar 20, 2006 | 02:16 PM
Default Re: (CRR 2)
no more bondo for me.. i wanna do it the right way and be done with rust
Old Mar 20, 2006 | 04:56 PM
carbonk20's Avatar
Default Re: (93CharcoalHatch)
I'm still looking for people that have used the replacement panel.
Old Mar 20, 2006 | 05:54 PM
sohc'd upEJ8's Avatar
Default Re: (carbonk20)
Your best bet will be to make patch panels out of sheet metal or get it off a donor car.....Make a template and mold/form the metal to desired shape.....Weld it in,grind it,get it as smooth as possible and if you do a decent job you shouldn't need to much bondo....Bondo will not crack if applied correctly and not exposed to moisture....I had to patch the rear quarters on an EF last year.....
Old Mar 21, 2006 | 12:19 PM
carbonk20's Avatar
Default Re: (sohc'd upEJ8)
No I'm looking for people that have used the frp patch panel. I'm curious about the fit and the time on the install. Anybody?
Vagitarian
Paint and Body
Apr 28, 2012 12:44 PM
g35silversurfer
Dec 4, 2010 07:05 AM
5.0 Killa
Welding / Fabrication
40
Jan 30, 2006 01:48 PM
JeremyL
Apr 1, 2004 06:24 AM
ebpcivicsi1234
Jan 13, 2004 01:18 PM
