H22a dyno @ 10 psi
Old Mar 20, 2006 | 10:19 AM
xrunner86x's Avatar
Default H22a dyno @ 10 psi
It's not in a Prelude but thought some of you might be interested.
Dyno at 10psi falling off to 9psi due to wastegate/lack of boost controller
JDM H22a
Darton Sleeves
Wiseco Pistons
Eagle Rods
ARP Head Studs
Cometic Head Gasket
Skunk2 Cam Gears
JDM transmission w/ LSD
Exedy 3 Puck Cerametallic Clutch
Exedy Pressure Plate
Clutchmasters Lightweight Flywheel
PSPEC Short Shifter
Walbro 255lph Pump
AEM Fuel Rail
B&M Fuel Pressure Adapter
RC 550cc Saturated Injectors
Hondata S200B P28
Precision SC6031B Turbo .48 AR
Drag Cast Manifold
Spearco Intercooler
GReddy Type-S Blow Off Valve
TiAL 38mm Wastegate
Custom Piping
Setup is currently limited due to clutch capacity and fuel injectors.
Old Mar 20, 2006 | 10:40 AM
mgags7's Avatar
turbo is a little big for your setup, a smaller one would spool earlier and your powerband would be wider
Old Mar 20, 2006 | 11:11 AM
chitownrida's Avatar
injectors are maxed? seems weird to me
Old Mar 20, 2006 | 11:18 AM
xrunner86x's Avatar
Well, the first limitation is that the clutch is slipping. If I had a better clutch, the injectors would be maxed before anything else.
Old Mar 20, 2006 | 11:19 AM
prelittlelude's Avatar
Default Re: (chitownrida)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chitownrida &raquo;</TD></TR><TR><TD CLASS="quote">injectors are maxed? seems weird to me
yeah runing at about 10 psi you approach 85% duty cycle, he could already be at more depending on what his fuel pres is set at, good numbers, hope its rfun to drive..
MrArney
Southeast (Sales)
Mar 19, 2012 07:25 PM
Guga
Apr 18, 2009 04:23 PM
raysjdmh22a
Apr 5, 2006 08:38 PM
HOTSHOT-H22A
Apr 22, 2004 03:33 PM
1fastgsrturbo
Jun 7, 2003 04:19 PM
