STop my breaks from squeaking.....
not on myintegra, but my mazda mx3....i recently had new rotors put on, and now they squeak when i brake....what can i put on them to stop them from squeaking.....i have a possible buyer today and i need to get it done quick...
TIA
[Modified by Yes it's VTEC, 5:38 PM 4/2/2002]
TIA
I'd A) recommend SANDING the rotors, using a circular, non-directional motion all the way around, making sure to CLEAN the rotors after you're done and B) pull the pads and regrease the backs and the shims w/ molykote M77.
A) might be easier, then do B) if that doesn't work.
Add some anti-squeal stuff on the backs of the pads. If that doesn't do it, then it might be the brake pads themselves--some pads are quiet and some are noisey
if you used your old pads with the new rotors it could be glazed pads. rough up the pad surface with some sandpaper and be sure to put the anti squeal liquid on the back of the pad. that should stop it. anyof the other suggestions might help, too, with the exception of the screwdriver trick... I'd stay away from that one.
H2290
10
Jul 28, 2006 01:56 PM
A.E Motoring
Nov 19, 2005 06:20 PM
rody084
Apr 18, 2003 05:32 PM
