Suspension & Brakes Theory, alignment, spring rates....
Balljoint Boot Replacement.
Old Mar 20, 2006 | 05:00 AM
TurboEM1's Avatar
Default Balljoint Boot Replacement.
I ripped the balljoint boot on the LCA a couple of months ago. I now have a replacement boot and cup and am wondering of any tips for this. I can succesfully pop the balljoint out and get to it, my main concern is
what grease to use?
any tips for getting that stupid clip back on?
Thanks
Old Mar 20, 2006 | 07:34 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Balljoint Boot Replacement. (TurboEM1)
The clip goes back on pretty easily. If you put a little grease on the outside of the boot, the clip will slide easily down into it's groove.
Any suspension grease will work fine for inside the balljoint. Since the boot seals in the grease, you don't have to worry about it washing away. Just ask parts store guy, what's the best grease for balljoints that they have...
Old Mar 20, 2006 | 09:17 AM
Tyson's Avatar
yeah its a really easy job as long as you know how to pop off the balljoint.
any grease will do.
Old Mar 21, 2006 | 08:37 AM
TurboEM1's Avatar
Default Re: Balljoint Boot Replacement. (Tyson)
just finished doing it. Took a lot longer then i wanted but it was my own fault. I spent like an hour trying to pop the balljoint out only to realize i must have got it on the first couple of tries. And that clip was a bitch for me to get on. I got it but it took a lot of finess (sp?). The parts guy recomended some premium mobil semi synthetic grease that said it was for cv joints-wheel bearings-chassis-and some other stuff. hopefully its ok.
Old May 4, 2006 | 08:01 PM
Takumi Fujiwara's Avatar
Default Re: Balljoint Boot Replacement. (apeng09)
where'd you get the boot from? mine just ripped the other day, I'm so pissed, this is my newer one of the new.
Old May 4, 2006 | 08:04 PM
Tyson's Avatar
Default Re: Balljoint Boot Replacement. (Takumi Fujiwara)
honda dealer?
Old May 5, 2006 | 04:36 AM
TurboEM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">honda dealer?</TD></TR></TABLE>
Yea i went to the honda dealer. the boot was $2.xx and the clip was $1.xx
Old May 5, 2006 | 07:23 AM
94eg!'s Avatar
#1 Super Guy
Loved
You can reuse your old clip if you don't bend it during removal.
Old May 5, 2006 | 11:19 AM
TurboEM1's Avatar
Default Re: Balljoint Boot Replacement. (94eg!)
yea i know. I got an extra one because i knew if i messed it up half way through the process i would have to order it and that would take like 3 days of driving with out it. It was cheap enough. Also it helped because i practiced with one on how to get it on then used the new one bc i bent the old one all up.
Old May 5, 2006 | 05:07 PM
Got it from the dealer! Employee discount yield a price of just over $1.00.
Looks good so far... I'll check it again when I rotate my tires for autocross this Sunday!
Never knew you could just buy the boot! Saved me money! Now that's MONEY!
CWBETB
Jul 20, 2007 09:23 AM
scartail
Suspension & Brakes
Aug 25, 2006 05:18 PM
JRciv
Mar 22, 2005 02:01 AM
fiebru1119
Mar 28, 2002 09:17 AM
