Break in and used some Sysntehtic oil
I have a brand new H23VTEC motor. Its built for Boost. So far I have put 17 miles on it. I put in at first Honda 5-30w. I poured it in and drained it out, no start up yet. Then I filled it with 10-30W Honda Oil Sysnthetic. I started it and let it ideal for 15, then a few other times for 5-10 minutes. I recently drove it for 17 miles. Driving was easy and no Abuse.
My Question is,
Will I have problems by continuing with the 10-30W Honda Oil Sysnthetic?
Should I drain it and go buy some SuperTech and Continue the Break in Period?
I was reading and searching but did not find my exact situation.
Any help will be apperciated.
Thanks Fellas,
JDM4DRACCORD
My Question is,
Thanks Fellas,
JDM4DRACCORD
Synthetic oil is the worst thing you could ever use on a fresh engine. It is too slippery and will not allow for proper break-in.
Run your conventional junk oil to break the engine in. 10w-30 is fine.
I would recommend putting in some regular oil in, running the engine for a few minutes, then doing another change to get all of the synthetic out of there.
I say run petroleum oil for 2k+ miles. The problem with synthetic oil is that it doesn't allow proper engine wear which is actually needed in a new or freshly rebuilt engine.
This is a complete guess though. Don't take only my word but the guy above said the same thing and he appear to know his stuff.
Breaking a motor in shouldn't really take 1000 miles. Its just a matter of getting the piston rings to set, correct? There are a lot of cars coming from the factory with full synthetic in the engine. All MB, AMG models come with synthetic out of the factory.
2001B18C1GS-R
22
Nov 7, 2011 08:14 AM
