ITR decelerates sharply in reverse with clutch in
Old Mar 19, 2006 | 08:41 PM
GRM Scott's Avatar
25 Year Member
Default ITR decelerates sharply in reverse with clutch in
This started the other day, I was backing up and things felt a bit jerky, but I thought nothing of it. Today I backed out again, and when I put the clutch in with the car engaged in reverse it felt like I hit the brakes, the car came to an abrupt halt despite being clutched into neutral. Sticky engagement/disengagement of reverse on the shift pattern as well. Search suggests that it's a shift fork, a 5th gear synchro, or possibly just bad fluid; anyone else experience the weird decelration I'm describing? Car coasts fine with clutch in from first gear going foward.
Thanks in advance for any theories or advice!
Old Mar 19, 2006 | 09:05 PM
JjuuN R's Avatar
my educated guess would be your synchro, i think if it was the fork it'd happen in other gears as well
Old Mar 19, 2006 | 10:07 PM
SoCal ITR's Avatar
Default Re: ITR decelerates sharply in reverse with clutch in (GRM Scott)
yes!
I've had that. I'm not a mechanic, but I "think" it has something to do wtih the main shaft being worn and unbalanced which throws other things off. I bet it feels like referse binds in gear sometimes too.
Old Mar 20, 2006 | 06:18 AM
GRM Scott's Avatar
25 Year Member
Default Re: ITR decelerates sharply in reverse with clutch in (SoCal ITR)
It does seem hesitant in reverse under power, although it's not resisting enough to really bog the engine. Either way looks like I'm going to have to crack it open, bleh.
Old Mar 20, 2006 | 07:08 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRM Scott &raquo;</TD></TR><TR><TD CLASS="quote">It does seem hesitant in reverse under power, although it's not resisting enough to really bog the engine. Either way looks like I'm going to have to crack it open, bleh.</TD></TR></TABLE>
Sounds like time for a picfest and writeup for some upcoming "Fixing the R" GRM article
Old Mar 20, 2006 | 08:24 AM
GRM Scott's Avatar
25 Year Member
Default Re: ITR decelerates sharply in reverse with clutch in (1GreyTeg)
Heh, that might be a little too specific for our reader base; What To Do When Your Limited-Edition 5-Year-Old Honda Backs Up Weird: REAL WORLD PEFORMANCE GAINS!
D was the last one in the tranny, he probably left his shirt in there.
Old Mar 20, 2006 | 09:23 AM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRM Scott &raquo;</TD></TR><TR><TD CLASS="quote">Heh, that might be a little too specific for our reader base; What To Do When Your Limited-Edition 5-Year-Old Honda Backs Up Weird: REAL WORLD PEFORMANCE GAINS!
D was the last one in the tranny, he probably left his shirt in there.</TD></TR></TABLE>
Probably, but at least he made sure the shifter bolt was tight!
Err... nevermind.
Old Mar 20, 2006 | 09:25 AM
D's Avatar
D
Default Re: ITR decelerates sharply in reverse with clutch in (Dave-ROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave-ROR &raquo;</TD></TR><TR><TD CLASS="quote">
Err... nevermind.</TD></TR></TABLE>
You're supposed to be getting old enough to forget about that ****.
Old Mar 20, 2006 | 10:27 AM
GRM Scott's Avatar
25 Year Member
Default Re: ITR decelerates sharply in reverse with clutch in (D)
I was a little bummed we never got to use the plastic washer made from a CVS shopping cart seat after I found the real washer in the middle of the busiest intersection in all of freaking Orlando...
Old Mar 20, 2006 | 12:13 PM
markpaco's Avatar
I had the same problem with my transmission. If you put the car in reverse and drive you can feel a drag. The drag is intermittent and varies with the rotation of the wheel. Also, when you leave it in reverse and let it coast with the clutch in (disengaged), the car will come to a stop consistent with the intermittent drag force.
Unfortunately, I don't know the fix as I went and bought a new transmission because I also had problems with popping out of 2nd gear. I was in the middle of a race season so I didn't want to deal with the downtime.
I'll be sure to chime in when I eventually rebuild the trans.
Old Mar 20, 2006 | 12:15 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: ITR decelerates sharply in reverse with clutch in (neo_)
I had that exact problem and it was mostly the shift forks. The synchros were also screwed up, but I'm not sure how related that damage was. Pain in the *** repair too.
Old Mar 20, 2006 | 12:59 PM
1fastVX's Avatar
Default Re: ITR decelerates sharply in reverse with clutch in (sscguy)
I have the same issue. It feels like there is resistance in reverse. Strange thing is all the other gears are fine and it drives fine in 1 through 5? So far I have not had the chance to pull the tranny and look at it. Let me know if you find out what is wrong!
John
Old Mar 20, 2006 | 01:24 PM
SoCal ITR's Avatar
Default Re: ITR decelerates sharply in reverse with clutch in (markpaco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markpaco &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem with my transmission. If you put the car in reverse and drive you can feel a drag. The drag is intermittent and varies with the rotation of the wheel. Also, when you leave it in reverse and let it coast with the clutch in (disengaged), the car will come to a stop consistent with the intermittent drag force.
I'll be sure to chime in when I eventually rebuild the trans. </TD></TR></TABLE>
That describes it perfectly. The reverse, plus the 2nd gear popping out, it's got to be related.
Old Mar 20, 2006 | 01:38 PM
Typer#23's Avatar
Same thing is happening to mine. Car decelerates in reverse and I cant put the car into 2nd gear unless it is from first to second. Been too lazy to pull the tranny and Im wondering if it might be better to buy my friends ITR Tranny.
Old Mar 20, 2006 | 01:39 PM
eg6r0ll
Guest
Posts: n/a
I have a hot tranny for you! Interest PM me.
Old Mar 20, 2006 | 01:48 PM
nightrider's Avatar
Default Re: ITR decelerates sharply in reverse with clutch in (eg6r0ll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6r0ll &raquo;</TD></TR><TR><TD CLASS="quote">I have a hot tranny for you! Interest PM me.</TD></TR></TABLE>
GTFO
Old Mar 20, 2006 | 02:21 PM
epoch707's Avatar
When the clutch was engaged, was reverse slower than usual? does giving it throttle bring it back or does it bogg? Im asking this because I think I have the same problem, just don't know whats wrong.
Old Mar 21, 2006 | 01:39 PM
GRM Scott's Avatar
25 Year Member
Default Re: ITR decelerates sharply in reverse with clutch in (epoch707)
There is some resistance with the car in reverse and the clutch engaged (pedal out), but it doesn't override the engine's torque at idle; leaving the car in reverse with no gas allows the car to maintain a constant idle speed in gear.
Those of you who have this problem, how long have you been driving around with it?
Old Mar 21, 2006 | 01:49 PM
epoch707's Avatar
I have been dealing with this problem since november 2005. I have the exact problem you describe...has anyone been able to fix this? how much would this cost
Old Mar 21, 2006 | 06:10 PM
SoCal ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRM Scott &raquo;</TD></TR><TR><TD CLASS="quote">There is some resistance with the car in reverse and the clutch engaged (pedal out), but it doesn't override the engine's torque at idle; leaving the car in reverse with no gas allows the car to maintain a constant idle speed in gear.
Those of you who have this problem, how long have you been driving around with it?</TD></TR></TABLE>
A few months, until I replaced it. The problem got progressively worse. Cause unknown.
Old Mar 29, 2006 | 05:58 AM
1fastVX's Avatar
Has anyone come up with more info on this issue yet?
John
Old Mar 29, 2006 | 12:03 PM
nafreak's Avatar
Default Re: ITR decelerates sharply in reverse with clutch in (1fastVX)
Might as well upgrade the FD while you are in there if you already havent.
Old Mar 29, 2006 | 01:15 PM
00R101's Avatar
Don't rule out stick brake adjusters on rear wheels. Chock the front wheels, release the e brake, jack up the car and see if the rear wheels turn freeely.
Old Mar 29, 2006 | 02:51 PM
D-Rob's Avatar
Default Re: (00R101)
Does the car have a hard time going into 2nd sometimes?
My B16 transmission did the same things you mentioned.
Turned out to be a bad countershaft bearing causing everything to bind up.
One day I guess it wobbled around too much, and some teeth from my countershaft decided to 'liberate' themselves through the bottom of my tranny casing.
Old Apr 10, 2006 | 12:50 PM
GRM Scott's Avatar
25 Year Member
Default Re: (D-Rob)
Weird you should mention that, just got back from Rally NY and second gear was being reluctant in some cases. Guess I should take the car offline before I frag something good....
FD is already upgraded, but this will be a good opportunity to get that Toda flywheel installed finally and upgrade the clutch.
