ls vs. gsr crank
Old Mar 19, 2006 | 05:43 PM
Slink2000's Avatar
Default ls vs. gsr crank
is there a difference?
Old Mar 19, 2006 | 06:35 PM
JDMC-Kamel's Avatar
Default Re: ls vs. gsr crank (Slink2000)
yes the LS has a longer stroke
i belive the GS-R is 87 mm stroke and the LS is a 89mm stroke
Old Mar 19, 2006 | 09:33 PM
Slink2000's Avatar
Default Re: ls vs. gsr crank (JDMC-Kamel)
can you use a ls crank in a gsr block without needing custom pistons, I want to built a motor with the gsr block and b16 head (poor man's type r). I was wondering which crank and rods to use, I will be using ctr pistons.
Old Mar 20, 2006 | 03:14 AM
NJIN BUILDR's Avatar
Gsr crank has narrow rod journals and you need to use the gsr rods with it.Gsr blocks and ls blocks are the same hieght.Ls rods and crank will work in a gsr block with ctr pistons.
Glenn
Old Mar 20, 2006 | 08:50 AM
Slink2000's Avatar
Default Re: ls vs. gsr crank (NJIN BUILDR)
Thanks
matt2320
Sep 7, 2010 04:42 AM
patrick4588
Oct 18, 2007 12:33 PM
bigbadboy
Aug 28, 2006 06:20 PM
EF9SIRJeff
Aug 24, 2005 11:07 AM
EH2LS
Apr 29, 2004 08:24 AM
