Alternator Problems
Has anybody has any on their R's? Mines a 2000 w/ only 19K kms on it.
On the weekend, I'm sitting at a light and my speedo goes crazy and my car starts revving all funny. By night all my lights inside and out are flickering on and off. I pull over turn the car off and it won't start. I let it sit for like 20 mins and it starts but all the lights are still going nuts. I've already changed my battery once because I don't drive my car during the week and by the weekend the battery is almost dead. I still don't know what's drawing current when my car is off. But after all the jump starts I think my alternator has had it. Any thoughts?
well my battery's been dying on and off when I'm away for work. I always have to jump it... i'm guessing it's my stereo system that's doing it but i haven't been able to nail down the problem yet. I've already changed my battery once cause my first one just stopped holding a charge i have a feeling this new ones gonna go soon..
Does your car die while you are driving it?
If it does, then it is probably your alternator.
Your gauges going crazy and the flickering of the gauges are probably the warning signs you see just minutes before the car dies, right? If so, this is more than likely the alternator.
damm happened to me last week..sitting at the lights speedo goes from 0 to 230km in a blink of an eye....then it idles rough...lights start dimming and im bout to cry.....alternator ..yep you got it no im smiling......
Honda's have very weak alternators with little in the way of "excess power" - they were built and designed to run the car - not some big *** stereo.
It sounds like you have an electrical problem that is related to your stereo. How many amps to you have? What kind of current load are they drawing?
I would upgrade the alternator if you are going to replace it.
hey man.........replaced your battery????...............I didn't drive my R for like 4 weeks at a time in the winter with no problems
has to be your stereo..........I sold my alpine type r's when i bought my R ......... stereo **** with your car so much.........i had a 1500 watt Alpine amp and I can now say i will never put a loud stereo in any of my cars ever again...........sure its all bling bling when your cruisin but so many compromises
[Modified by 01-1293, 9:53 PM 4/15/2002]
check the fuse of the alternator under your dash. that fuse take care of all the speedo, light and so on. if that fuse blown, then better check where is the short.
to check the alternator, get a voltmeter. with the car off, check the battery voltage. should be approx. 13-13.5volts. now start the car and with it at idle or a little above, the voltage should read approx. 14-14.5 volts. keep all the other electrical stuff off in the car. voltage readings should be steady with no wild dips. if you start the car and the voltage stays the same as the original battery voltage, your alternator is most likely bad. have the dealer look it over and see if they'll cover it or not. can't hurt. good luck.
my alternator was bad so i changed it...was getting same problems...noticed i was blowing fuse for speed sensor...i had a short in my 02 sensor soon as i changed it car was ok....
How do the underdrive pulleys affect the reliability of an alternator?
V. - who's ITR runs on the battery at idle.
