Suspension & Brakes Theory, alignment, spring rates....
brakes?
Old Mar 19, 2006 | 03:00 PM
EJ8 GSR-T's Avatar
Default brakes?
I was not sure exactly what this fit under, but i saw a mustang today with black rotors. Not like it was just a break in material, but the rotors were black and it looked amazing. Anyone know about this?
Old Mar 19, 2006 | 06:17 PM
EJ8 GSR-T's Avatar
Default Re: brakes? (userdead626)
Old Mar 19, 2006 | 06:34 PM
94eg!'s Avatar
#1 Super Guy
Loved
It will look the nicest if you dissconnect the caliper from the hub (not the brake hose) & hang it from a coat-hanger wire inside the wheel well. Make sure to clean all the surfaces to be painted VERY well, and mask EVERYTHING that you don't want to be painted. Also make sure to mask off the wheel well & parts of your fenders that might be hit by overspray.
Do several lighter coats to avoid runs. Once you build up a couple light coats, one heavier coat should stick well & leave a nice shiny surface coat (unless your using matt finish paint).
Make sure to use a good high temp ceramic paint like engine or brake paint. Also, make sure to let it dry for a couple hours before you touch them. fingerprints are ugly & permenent.
Old Mar 19, 2006 | 06:50 PM
EJ8 GSR-T's Avatar
Default Re: brakes? (94eg!)
yeah, i believe you are speaking of the caliper? I was talking more about the rotor itself
Old Mar 19, 2006 | 10:29 PM
chrisw85's Avatar
i remember AEM having black rotors.
Old Mar 20, 2006 | 02:28 PM
dcRay's Avatar
Default Re: (chrisw85)
Powerslot now.
Old Mar 20, 2006 | 02:46 PM
CRR 2's Avatar
brembo does if remember right
Old Mar 21, 2006 | 10:51 PM
91tealhatch's Avatar
Default Re: (CRR 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRR 2 &raquo;</TD></TR><TR><TD CLASS="quote">brembo does if remember right</TD></TR></TABLE>
Nighthawk R18
Feb 11, 2006 10:08 AM
FK00GSR
May 31, 2005 07:15 AM
B2FiNiTY
Jul 19, 2004 10:11 AM
sleepyhamsterlx
12
Dec 19, 2002 06:50 PM
AK94GSR
Jun 22, 2001 11:58 AM
