H23 head on a H22 block?
Old Mar 19, 2006 | 02:42 PM
Kwalsh24's Avatar
Default H23 head on a H22 block?
Ok I attempted a search on this issue but wasnt sure hpw to word it to get the matchs I wanted. Anyhow will a 93 h23 head fit a 00 H22 block? If it does what issues would I have with tuning the head to work with the smaller sized engine block? Or will there be any issues? The H22 is a 2.2l and the H23 is a 2.3L.... THis will probably turn into a slow step by step vtec H22a buildup..... Just low on funds and cant afford the entire swap all at once and there is a good deal on a block close to home.... wuld pick it up if my head will fit it for the time being while I save up for the rest...
Old Mar 19, 2006 | 02:44 PM
mark45840's Avatar
Default Re: H23 head on a H22 block? (Kwalsh24)
https://honda-tech.com/zerothread?id=510617
that will tell you everything you need to know
Old Mar 19, 2006 | 02:53 PM
Kwalsh24's Avatar
Thats talkin about using a H23 block buildup tho, I wanna know if the head off of a h23 will fit a h22.... Or did I missread? Odd request I know, What are the advantaged of a h23vtec over a H22? Is it just power to tourqe ratios?
Old Mar 19, 2006 | 02:55 PM
md23vtec's Avatar
Default Re: (Kwalsh24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwalsh24 &raquo;</TD></TR><TR><TD CLASS="quote">Thats talkin about using a H23 block buildup tho, I wanna know if the head off of a h23 will fit a h22.... Or did I missread?</TD></TR></TABLE>
Yes It will work ( *tip* make sure you use the H23 heads bolts )
Old Mar 19, 2006 | 02:57 PM
Kwalsh24's Avatar
Cool so no odd issues would occure? Do i just use a H22 head gastget to put the H23 head on?
Old Mar 19, 2006 | 03:00 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwalsh24 &raquo;</TD></TR><TR><TD CLASS="quote">Cool so no odd issues would occure? Do i just use a H22 head gastget to put the H23 head on?</TD></TR></TABLE>
H23head gasket. Also you going to have to use all the H23 timing stuff ( camgears, crankgear, waterpump, timing belt, ect, ect
Old Mar 19, 2006 | 03:03 PM
Kwalsh24's Avatar
Default Re: (md23vtec)
Ok well thats cool casue I have all that anyhow since my car is stock with the H23 so basically jsut transfer everything from one engine to the other.... Does the H22 use 2 timing belts like the H23? or just 1?
Old Mar 19, 2006 | 03:05 PM
Kwalsh24's Avatar
Will there be any odd tuning issues or will it be a direct part swap put her in and she will fire and run the way she should? Then when I go get the H22 head i'd aveta go all out and get all H22 parts....
Old Mar 19, 2006 | 03:08 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwalsh24 &raquo;</TD></TR><TR><TD CLASS="quote">Ok well thats cool casue I have all that anyhow since my car is stock with the H23 so basically jsut transfer everything from one engine to the other.... Does the H22 use 2 timing belts like the H23? or just 1?</TD></TR></TABLE>
I would switch over the tensioner setup off the H23. Yes it has 2 belts 1 timing belt 1 balancer belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwalsh24 &raquo;</TD></TR><TR><TD CLASS="quote">Will there be any odd tuning issues or will it be a direct part swap put her in and she will fire and run the way she should?</TD></TR></TABLE>
Tuning Issues? Use the H23 ecu and injectors you should be good to go
Old Mar 19, 2006 | 03:10 PM
Kwalsh24's Avatar
hmm ok cool.... Think I may consider this..... The fun will be when i do the top end conversion.... and well yea i am gunna use my H23 topend, injectors intake everything, how about the manifold is that drastically different?
Modified by Kwalsh24 at 7:20 PM 3/19/2006
Old Mar 19, 2006 | 03:19 PM
gospeedracerh23's Avatar
whats wrong with your h23 block?
Old Mar 19, 2006 | 03:22 PM
Kwalsh24's Avatar
I think it has a weak cylinder startin to burn a little bit of oil on startups but after that she is fine..... And well there is a deal near me thata guy is sellin a H22 block for a 2000 lude for cheap was thinkin bout gettin it
Modified by Kwalsh24 at 7:49 PM 3/19/2006
Old Mar 19, 2006 | 03:38 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwalsh24 &raquo;</TD></TR><TR><TD CLASS="quote">hmm ok cool.... Think I may consider this..... The fun will be when i do the top end conversion.... and well yea i am gunna use my H23 topend, injectors intake everything, how about the manifold is that drastically different?
Modified by Kwalsh24 at 7:20 PM 3/19/2006</TD></TR></TABLE>
You have to use the H23 intake and exhaust manifolds, the H22 manfolds wont work.
Old Mar 19, 2006 | 03:50 PM
Kwalsh24's Avatar
OMG yea duh I am an idiot! my god I feel stupid....
Old Mar 19, 2006 | 03:51 PM
md23vtec's Avatar
goodluck
Old Mar 19, 2006 | 03:55 PM
Kwalsh24's Avatar
ty otta be fun haha
Old Mar 20, 2006 | 02:32 PM
limpmode's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">
or just go ahead and eliminate the balancer shafts
Old Mar 20, 2006 | 02:57 PM
md23vtec's Avatar
Default Re: (limpmode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpmode &raquo;</TD></TR><TR><TD CLASS="quote">
or just go ahead and eliminate the balancer shafts </TD></TR></TABLE>
another possiblilty
Old Mar 20, 2006 | 07:21 PM
darockstar's Avatar
1st time hearing about this set-up good luck
Old Mar 20, 2006 | 09:19 PM
JTCdudeman's Avatar
Master H Technician
Default Re: (darockstar)
I always laugh at this setup... It honestly isnt worth the time and effort.. Just stick with your bottom end and find an h22 head in the meantime.. With all the changing over you have to do, there no point... the head has 53.8cc combustion chamber... the h22 has the same and vtec... Where will the gains come from aside from slightly higher compression(9.8:1 to 10.0:1)? Just wait it out boss...
The only benefits of this swap are keeping the exhaust manifold fitment...
Old Mar 20, 2006 | 09:22 PM
Rosko's Avatar
Default Re: (JTCdudeman)
At least throw the h23 crank and rods in and use the vtec pistons so when you do get an h23 head youll be h23 vtec ready
h23sol
Oct 15, 2008 11:29 AM
pkolaboy
Feb 19, 2008 06:37 PM
brad_prelude
Dec 16, 2004 10:23 AM
H23LUDE92
Jul 14, 2004 08:19 PM
