Did a leak compression test....are these god numbers?
Old Mar 19, 2006 | 12:42 PM
mraudio13's Avatar
Default Did a leak compression test....are these good numbers?
225,225,225,225
8%,8%,9%,10%
It's an 01 GSR with t3t4 turbo boostin 10lbs with hondata.
The reason I did the test is that I am having some real bad smoking issues. I have been messing with an oil catchcan and I think it might be the culpret. The way I have it hooked up is black box to catchcan and valve cover to catchcan venting to atmosphere, no PCV valve is installed.It is either that or valve seals. Any suggestions?
Thanks in advanced,
Matt
Old Mar 19, 2006 | 12:45 PM
96 GSR-T's Avatar
Default Re: Did a leak compression test....are these good numbers? (mraudio13)
You have what I would call a high compression perfect engine......good luck
Old Mar 19, 2006 | 12:47 PM
RTW DC2R's Avatar
yeah those numbers are fine. compression even across the board, and once you get up to 15% or higher on the leakdown, youll wanna worry.
Old Mar 19, 2006 | 01:11 PM
mraudio13's Avatar
Default Re: (RTW DC2R)
Thanks for the quick replys.
sirt_eg
Jun 16, 2009 01:25 PM
acman1
May 21, 2007 12:06 PM
JFG Kevin
Jul 19, 2006 07:49 PM
EF8_SiR
Jul 20, 2003 10:24 PM
RATEDR
Jun 6, 2002 03:24 PM
