H22a head on F22a block
Old Mar 19, 2006 | 12:39 PM
sluger17's Avatar
Default H22a head on F22a block
Can you swap a H22a head onto a F22a block if its possible what will you need to make it work and will it perform like a H22
Old Mar 19, 2006 | 12:49 PM
YeuEmMaiMai's Avatar
Default Re: H22a head on F22a block (sluger17)
yes it works do a search on "G series" and you should find what you are looking for
Dmc1's Avatar
Yes it works.their are some threads over in the prelude forums stickied at the top of the page and will tell you everything you need to know about the head swap.
It won't perform like an h22 though.The bottom end of an f22 just isn't made to rev to 8000 rpm.and you will have less compression so less power.
Old Mar 19, 2006 | 01:01 PM
93.2's Avatar
Default Re: H22a head on F22a block (Dmc1)
yea.... its an alright setup...
Old Mar 19, 2006 | 01:25 PM
chile's Avatar
Default Re: H22a head on F22a block (g-wagon)
search here, cb7tuner.com, etc...been done.
Old Mar 19, 2006 | 07:43 PM
XiOus271's Avatar
the G-series can be torque monsters if you build it up right. piratemcfred made more torque than hp, but he used an h23/f23. prelittlelude did a h22/f22, but i dont remember his dyno numbers.
Old Mar 20, 2006 | 10:56 AM
2cams4doors's Avatar
anything is possible with the right amount of money...
Old Mar 20, 2006 | 06:23 PM
BoostedH23Accord's Avatar
Default Re: (2cams4doors)
I did the swap and wouldn't you know it I have an H23 head for sale. You can use your Accord non-Vtec ECU and I have the working distributor the JDM H22 fuel rail and all nessesary parts to make it happen. Everythings for sale. Hit me up.
https://honda-tech.com/zerothread?id=1557832
Old Mar 21, 2006 | 11:37 AM
93.2's Avatar
Default Re: (BoostedH23Accord)
i got a f22/h22.... but yea... i had a f22/h23.... either one is ok... great for boost... just going the h23 route is alot cheaper...
all_motorsi
Feb 18, 2010 04:01 AM
Civic5Lug
Dec 15, 2003 11:35 AM
preluder
Apr 23, 2003 07:36 AM
AcCoRd_HyBrId
May 5, 2002 10:00 AM
94h23si
Aug 30, 2001 11:22 AM
