Need Help Identifying what all of these are!!!!
Okay. In my search for finding out how to get my cd player, clock, and interior light to work, i've come across a few things that i have questions about. Here are the pics:
#1. Located where the cd player goes. The top right circle is just a connecter that is sitting there i was just wondering where it is supposed to go. The bolt had a spade connecter on it with a little wire in it just wondering if that has any importance. And finally the bottom left. That has a wire coming off one side that it not connected to anything its just and unstripped red wire. the other side of it goes to a brown connecter that attaches above the fuse box.
#2 Okay this is located in the same spot as the above one. Its just a long black box with like the strip on one side. Just wondering what this may be for.
If you need anymore pics of info just ask.
Albert
Albert
That top right one is similar to the clock wire I think, but not sure how it could get all the way down there.
The bolt was probably a ground they put in, &the bottom left looks like they tapped the cig lighter for a power.
okay do you have any idea what would need to be grounded right there? also the cig lighter has a totally different wire. the top right turns into a orange and black wire that connects into a little metal box. the box says 12v on the side. at one point when i held the reset button the clock woud turn on and then proceed to turn off so im not thinking its the clock power.
If you had someone do the wiring, or install w/e,
they probably just found it seemed like a good grounding spot.
Was there any wire, or Just the spade? it wasn't crimped, and the wire came out eh?
no there is a little peice of wire in it and it was crimped so thats why i was wondering if there was anything that might belong there. well i took out all my turbo stuff before which included two gauges wired right above that and it all worked before i pulled that stuff out so i guess i must have fucked something up when i did that.
yea well if the clock was unplugged would that cause the clock and interior light to not work also?
97civic123
Audio / Security / Video
Mar 28, 2004 06:54 AM
