T4 flange to a t25 flange manifold?
Old Mar 19, 2006 | 11:48 AM
b18c5GT2871R's Avatar
Default T4 flange to a t25 flange manifold?
On my exhaust manifold i have a T4 flange and my turbine(gt2871r) has a t25 flange.
is there a special flange i can fix between both or something else??
thx
Old Mar 19, 2006 | 12:03 PM
Turbocivic94's Avatar
Default Re: T4 flange to a t25 flange manifold? (b18c5GT2871R)
That looks like a T3 flange
Old Mar 19, 2006 | 12:21 PM
Default Re: T4 flange to a t25 flange manifold? (Turbocivic94)
the turbo or the manifold??
Old Mar 19, 2006 | 12:24 PM
TUrBo InTegRa 16's Avatar
I had the same problem when i bought my turbo. What i did was weld the holes on the exhaust manifold to cover up the holes and then drilled new holes to fit the size of the turbo.
Old Mar 19, 2006 | 12:35 PM
it does not matter if the size of the turbo hole and the size of the manifold hole is not the same. ill be restrictive??
Old Mar 19, 2006 | 01:51 PM
paulzy's Avatar
cut it off and weld a t25 flange on the manifold or bring it into a machine shop and tell them you want those to fit together and you need an adater plate.
Old Mar 19, 2006 | 02:11 PM
stockredej1's Avatar
BMC makes adapters i think. there website is bmcrace.com i think.
Edit: http://bmcrace.com/products/adapters/ If you cant find it on there email them im sure they can make you one.
Old Mar 19, 2006 | 03:10 PM
igo4bmx's Avatar
is that an ssautochrome manifold!?
Old Mar 19, 2006 | 04:17 PM
paulzy's Avatar
Default Re: T4 flange to a t25 flange manifold? (stockredej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockredej1 &raquo;</TD></TR><TR><TD CLASS="quote">BMC makes adapters i think. there website is bmcrace.com i think.
Edit: http://bmcrace.com/products/adapters/ If you cant find it on there email them im sure they can make you one. </TD></TR></TABLE>
there you go....$50 for the adapter
Old Mar 19, 2006 | 04:20 PM
Soccerking3000's Avatar
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">is that an ssautochrome manifold!?</TD></TR></TABLE>
looks like a sparks racing?
Old Mar 19, 2006 | 05:11 PM
i dont know about the brand of my manifold but its not an SSauto. thats was on a fully-built gsr
theputz
Oct 15, 2009 08:07 PM
nitroice40
Welding / Fabrication
Apr 6, 2006 03:11 PM
SOHCD16y8
Jun 10, 2005 08:04 PM
ORcivicsi
Aug 20, 2004 10:50 PM
JDM EJ1 95
Aug 18, 2004 04:45 PM
