BSPT to NPT fittings
Old Mar 19, 2006 | 08:29 AM
Diego Dangers.'s Avatar
Default BSPT to NPT fittings
anyone know where I can find BSPT to NPT fittings? I cant seem to find them on any of the websites
Old Mar 19, 2006 | 08:36 AM
stealth-wrx's Avatar
Default Re: BSPT to NPT fittings (Diego Dangers.)
http://www.mcmaster.com sells them.
Type this in at the search box: bspt to npt
Old Mar 19, 2006 | 08:40 AM
thanks, but I suck. I typed that in, and its showing me PG fittings. I do know that BSPT is british standard, is it the same as European Standard? (PG)
Old Mar 19, 2006 | 08:42 AM
dfoxengr's Avatar
Default Re: (Diego Dangers.)
no its not the same.
Old Mar 19, 2006 | 09:09 AM
Default Re: (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">no its not the same.</TD></TR></TABLE>
thanks, thats what I figured.
Old Mar 19, 2006 | 10:50 AM
dennis's Avatar
for oil pressure fitting. Pretty sure it's mcmaster part# 4860K141 $3.91
Old Mar 19, 2006 | 11:09 AM
Default Re: BSPT to NPT fittings (dennis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennis &raquo;</TD></TR><TR><TD CLASS="quote">for oil pressure fitting. Pretty sure it's mcmaster part# 4860K141 $3.91</TD></TR></TABLE>
thanks alot man, really appreciate it.
Old Mar 19, 2006 | 11:34 AM
dennis's Avatar
no problem. Tuner toys also has http://tunertoys.zoovy.com/product/OTODK but it's about $20.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Our dual fitting has the correct male end to mate with the factory oil sensor port on you Honda engine block (Male 1/8 BSP). On the opposite end is the correct female end to accept the factory sensor (Female 1/8 BSP). On two sides of the fitting are the oil take-off ports, where you can install any two 1/8 NPT fittings for feeding your turbo, VTEC, or oil gauge! That's right NPT and BSP threads in one fitting! No more adapters and mismatched thread pitches! The dual fitting has an additional NPT port on the opposite side, which cannot be see in the photo.</TD></TR></TABLE>
Old Mar 19, 2006 | 11:57 AM
2kjettaguy's Avatar
I make a few BSPT adaptors for the EVO's and other DSMs. I make the following:
3/8" BSPT - 1/8" NPT male
3/8" BSPT - 1/8" NPT male 45°
3/8" BSPT - 1/8" BSPT
Let me know if any of those are what you need and I will link you to my website.
Evan
Old Mar 19, 2006 | 12:53 PM
Default Re: BSPT to NPT fittings (2kjettaguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kjettaguy &raquo;</TD></TR><TR><TD CLASS="quote">I make a few BSPT adaptors for the EVO's and other DSMs. I make the following:
Evan </TD></TR></TABLE>
PM me a link anyways, I am doing this same setup for a friend of mine that owns an Evo. I'll take a look at it.
But the last guy got it right on the money, I need 1/8" BSPT to 1/8" NPT
Old Mar 19, 2006 | 02:25 PM
2kjettaguy's Avatar
PM sent with a couple links
Old Mar 19, 2006 | 11:00 PM
B18EG6's Avatar
diego check the link in my signature if you get confused
Old Mar 20, 2006 | 02:26 AM
damn, informative link. I bought all fittings and lines after this from AN-Plumbing, and it cost me like 79 dollars. I feel so used.
steveharrmr23
Oct 14, 2008 02:20 PM
b00stedbyFastrax
Oct 9, 2007 07:51 PM
rice a roni
Mar 28, 2007 04:55 AM
axionm1k
Sep 24, 2006 06:20 PM
thecoolerguy
Oct 3, 2004 02:39 PM
