Why my car has lost power after engine repair??! :(
Hi,everyone!
There is a problem that bothers me for about two months now..
I my EG Civic with d16z6 ran faster than after engine repair and few mods..
I had to change oil rings for my d16z6 because of oil loss. So I decided to change piston rings and engine bearings. Mechanic had no problems by putting it together & even could turn crankshaft by hand when the engine was already screwed together. I also bought and installed OBX 4-2-1 header, full 57mm exhaust, lighten stock flywheel, d16y8 intake manifold, new spark plugs and wires and air filter.
So my Civic is slower now and gas mileage has increased!!!??
* ignition is adjusted already!
I want to do ECU programming,but I think I have to solve this problem before it..
So what could be possible problems???
I will appriciate any information and suggestions,thanks!
Before mods and repair & could easely win other d16z6 I can't even get now and the same thing's to my friends 3rd gen Si Prelude.. They're just faster now without doing anything to their cars..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt »</TD></TR><TR><TD CLASS="quote">your butt dyno is broken
i wish i had better gas mileage..
run a couple test, compression test, leakdown, vacuum, see what the results are, if they're all good and you still cna't figure out why, just throw a turbo on there..problem solved</TD></TR></TABLE>im betting he means his MPG went down... but maybe hes complaining about it being higher..
Leecivic16v
25
Jul 19, 2018 06:51 AM
Korey Klausing
Nov 19, 2016 06:36 AM
justa4banger
Nov 10, 2008 07:43 PM
