Suspension & Brakes Theory, alignment, spring rates....
Will EK shocks fit my EF?
Old Mar 19, 2006 | 07:20 AM
SVOboy's Avatar
Default Will EK shocks fit my EF?
Specifically the front stuff. I have heard EG fit with EG front forks and vice versa, wondering if the same can be said of EK shocks or if they will just fit modification free. Thanks a lot.
Old Mar 19, 2006 | 07:24 AM
PIC Performance's Avatar
Default Re: Will EK shocks fit my EF? (SVOboy)
Your EF's front fork is a touch too small to fit the EK's shock bodies, which are slightly thicker. You will need to use EK front forks. In the rear, your EK's lower mounts will be too narrow to fit the EF's LCA, and you will need to grind down the bushings about 5mm on each side to accomodate the EK's narrow lower fork.
Old Mar 19, 2006 | 07:33 AM
SVOboy's Avatar
Ah, well, someone local is selling just EK front gr-2s that're barely used, so I'm wondering mainly about getting them now. I have also heard that the brake lines won't mount up properly if I use the EK stuff, what do you think about this?
Old Mar 19, 2006 | 07:38 AM
Default Re: (SVOboy)
If the shocks do not have their own mounting brackets for your lines, then you will have no place to mount the stock lines' brackets to the shock, afaik, but I am not familiar with the GR-2's. Its not a huge deal, zip ties can take care of any flopping brake lines.
Hit up the local bone yard to pick up the EK's front forks if you intend to use them.
Old Mar 19, 2006 | 07:43 AM
SVOboy's Avatar
I was just at the junkyard yesterday and they didn't have any EKs, , I guess I'll have to find someone parting out a car or something. Thanks for all the help.
Old Mar 19, 2006 | 09:26 PM
Freeltec's Avatar
eg forks work aswell
Old Mar 20, 2006 | 04:02 PM
SVOboy's Avatar
Default Re: (Freeltec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freeltec &raquo;</TD></TR><TR><TD CLASS="quote">eg forks work aswell</TD></TR></TABLE>
Same as ek?
Old Mar 29, 2006 | 12:38 PM
RexQ's Avatar
yes
alperx
May 22, 2012 06:34 PM
DC2R82
Sep 8, 2010 03:39 PM
hmtcrxsir
Oct 4, 2007 09:26 AM
sporkcrx
Sep 26, 2004 05:46 PM
vizsual00
May 14, 2004 06:50 AM
