IDLE question
Old Mar 18, 2006 | 09:17 PM
NeWnMpR0VeD's Avatar
Default IDLE question
i have a JDM D15B with a complete greddy 15G setup... with a kenji p06 ecu with vtec conversion programmed for my 550'z.... ok, i removed the FMU once i installed the injectors and ecu... now my idol is all weird... it jumps up n down from 800 - 1300 RPMs... what can i do to fix this ?? would a missing link have anything to do with this ?? or my check valve ?? before i installed the injectors, it was previously on a p28 with fmu on stock injectors, and it idol'd fine... any help would be much appreciated...
Old Mar 18, 2006 | 09:40 PM
matt56's Avatar
i dont know if youve ever seen the omniman b16 dvd but when he was dyno tuning his car it loaped relly bad up and down like 800 to 1300 or so just like yours is and it was because the car was running a little bit to lean and when he corrected and added fuel it imedietly ran perfect. just a thought.
Good Luck
Old Mar 18, 2006 | 10:19 PM
^^ thanks for the info.... more info would help... running a bit lean is the last thing i would think my setup is doing
Old Mar 18, 2006 | 11:03 PM
postman's Avatar
Default Re: IDLE question (NeWnMpR0VeD)
your iac might just be going through relearning process drive like 10 miles and shut car off then restart withouyt disc. batt might go away
Old Mar 19, 2006 | 10:39 AM
i'll try that, just removed my missing link and its still boucin up n down
Old Mar 19, 2006 | 02:21 PM
help meeee
Kimbo
May 23, 2003 05:17 PM
Herminator
Feb 1, 2003 08:47 AM
TURBOED-TEG
Nov 21, 2002 04:25 AM
red civic standard
Nov 15, 2002 02:06 PM
slowsi00
Oct 10, 2002 12:48 PM
