del sol swap info needed ><"
Old Mar 18, 2006 | 08:39 PM
nekoabandoned's Avatar
Default del sol swap info needed ><"
this has been talked about alot im thinking,but i need to know what all i need to swap a ls motor in to my del sol. ive heard things like all i need mounts wise was right motor and rear tranny mounts ,is this true? also im thinking that ill need del sol dohc shift linkage,long block,tranny,ecu,axles, what am i missing? please no SEARCH answers thank you, also only facts
Old Mar 18, 2006 | 11:22 PM
Default Re: del sol swap info needed ><" (nekoabandoned)
bumps #1
Old Mar 19, 2006 | 04:53 PM
lps
Old Mar 19, 2006 | 05:00 PM
pythoner's Avatar
what motor is in there? is it a vtec?si?s?
more info and spaces help
Old Mar 19, 2006 | 05:06 PM
sykotik sol's Avatar
ok, i just did a 01' gsr swap in my sol...i used all the gsr mounts(ls mounts same), i used the gsr wire harness(use ls harness), i did have to get a dohc vtec sol shift linkage (paid 130 @honda) the front tranny mount and front block mount i had to swap the bushings from sol to the gsr mounts..other than that i had a lil issue w/ ecu because of obd2( so check what motor your gettin (obd1-2), so while im waiting on my s100 p28 im just running a stock p28 just to drive it...sohc specs suk but if you get obd 2 motor you wil have to get a harness for ecu ..lol, hope it helped bro...oh yea and the obvious motor, tranny, axles, and others mentioned above....
Old Mar 19, 2006 | 08:31 PM
Default Re: del sol swap info needed ><" (sykotik sol)
thanks man
PinoyDelSol
Nov 4, 2007 06:31 PM
sprmnrcr17
May 23, 2006 06:57 PM
bjfisher
Jan 8, 2006 05:44 AM
90civichb
Jun 5, 2004 04:13 AM
