how to fixes engine codes 41 Primary oxygen sensor heater
i think the best way would be to just replace the o2 sensor with a new one........check ebay for a denso o2 sensor.....should only be about 45.00 or so
Had the same problem. Thats the o2 heater. Before you replace the o2, check to make sure it is getting the right voltage, or it wont work. If youve got a bad connection, run the heater wire to the positive on the map or tps sensor. That would be a quick fix.
JoshJosephKeith
May 4, 2009 04:38 PM
slwazgsr
Oct 17, 2002 06:53 PM
