Fuel pressure for LS?
Old Apr 1, 2002 | 10:43 PM
White98LS's Avatar
Default Fuel pressure for LS?
Hey, I was wondering what the stock fuel pressure for a '98 LS is, with the vacuum hose on or off.
I got Crower 62403 cams in a week ago and the car ran okay, but the CEL was giving me a 45: too rich/lean. I got a B&M FPR and set it to 43psi with the vacuum off and plugged, 33psi vacuum on. It has more power, idles much smoother, sounds much more like it did before I put in the cams, and most importantly the CEL has turned off. YAY!! The thing is, I was an IDIOT and installed the FPR at the same time as the gauge, forgot to check the stock pressure and now it's too late. So I just need some stock numbers, I know every one is different but a range would be good to know. I'm pretty sure I'm running richer now though because cams take in more air right? Thanks for the help.
fieromadman
Apr 29, 2006 06:37 PM
2k.civic.si
Jan 4, 2005 08:51 AM
hi mom
May 23, 2003 08:45 PM
JMX
Mar 15, 2002 09:53 AM
