What are these 4 wires supposed to be connected to?
Old Mar 18, 2006 | 02:00 PM
ctownintegra's Avatar
Default What are these 4 wires supposed to be connected to?
Starting my wire tuck and engine bay buff. Noticed that these wires run to nothing, but my headlights, and turn signals still work fine. Also one of the grounds goes to nothing also.
Heres 2 pics, I would like to have it wired up right, or remove these wires alltogether since everything else works fine.
Runs thorugh the firewall grommett.
[img=http://img480.imageshack.us/img480/1912/1000947small7eh.jpg]
The 3 wires.
Old Mar 18, 2006 | 04:34 PM
v-tec maz's Avatar
Default Re: What are these 4 wires supposed to be connected to? (ctownintegra)
need a better pic. i cant seee anything
Old Mar 18, 2006 | 09:45 PM
Old Mar 18, 2006 | 10:50 PM
JeffRocksYoSocks's Avatar
Default Re: (ctownintegra)
haha i dont know you tell me!! hahah was the car coverted, swapped, etc?
Old Mar 18, 2006 | 10:57 PM
JDMorgan's Avatar
if the grommet is about 1" round, then it might be oem alarm siren + hood sensor wiring. is your car 98-01? remove the lower dash panel on the driverside. check on the passanger side of your steering column under your dash to see if you have an oem alarm.
Old Mar 18, 2006 | 11:07 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctownintegra &raquo;</TD></TR><TR><TD CLASS="quote">
The 3 wires.</TD></TR></TABLE>
fixed your pic link for ya
Old Mar 19, 2006 | 05:31 AM
Its a 95 GSR, and its not the alarm harness, it ran near the abs and down to the headlight and just stopped.
Old Mar 19, 2006 | 07:38 AM
xxxmikenicexxx's Avatar
Anyone correct me if Im wrong, but the only wires running all the way up to the nose of the car should be for headlights, fogs, turn signals, AC, PS, fans, horns, grounds for the body connectors, and windshield wiper motor. Have you deleted AC? Are BOTH horns working? If you cant figure it out, let me know what the wire colors are and Ill check in my Helms. Let us know if you come to any conclusion, good luck
Old Mar 19, 2006 | 01:19 PM
Red, White and Yellow with a Red Stripe.
Harness runs into the hole in the firewall near the battery.
Old Mar 20, 2006 | 09:35 PM
I think I'm just gonna cap them and hide them somewhere in case I need them.
Old Mar 20, 2006 | 09:43 PM
94~GSR's Avatar
i think its your turn signal...
Old Mar 21, 2006 | 11:44 AM
Nah, because they work fine. If someone could run outside and snap a pic fo where these wires run that would help alot. It runs around the strut tower then under the ABS stuff then stops at the headlight (where mine was cut)
Old Mar 21, 2006 | 12:34 PM
ROOROWNS's Avatar
Stock headlights and foglights on the car?
Wiring Diagram Time!
Good Luck
Bump for answers
Old Mar 21, 2006 | 05:32 PM
No Stock Fogs on this 95 GSR.
Now with a 98+ front. No fog switch inside and I can't tell where the wires go when looking from the inside.
There's gotta be someone that can snap a pic if their's has it.
Old Mar 21, 2006 | 07:16 PM
gsr dood's Avatar
where does the other end trace back too?
Old Mar 21, 2006 | 08:30 PM
JDMorgan's Avatar
not to sound like i'm ignoring you when you said it's not an alarm, but the colors are correct for an oem alarm, and they are pretty much the only thing honda ran on its own loom in the integra engine bay. did you check if you have an oem alarm? it could even be disabled...
Old Mar 21, 2006 | 10:17 PM
I have the OEM Alarm, maybe this went to a hood sensor that I don't have. All the other alarm wire run to the driver side.
2.3lcivic
Sep 27, 2007 11:28 PM
kixcrx
Feb 14, 2007 04:15 AM
kixcrx
Jan 10, 2007 06:36 PM
djgruesome
Jul 3, 2006 01:37 AM
jordan-boxer
Audio / Security / Video
12
Nov 21, 2005 09:18 AM
