gsr brakes on del sol help!!!
Old Mar 18, 2006 | 01:48 PM
eg2phosizzle's Avatar
Default gsr brakes on del sol help!!!
so i just swap out the front spindels i reused my del sol upper control arms because the integra ones were a lil too wide...i couldnt use my delsol shocks and struts so i had to use the integra ones...the problem is that the spidles are rubbing on the springs....wtf...and also camber is crazy off...im talkin bout it looks like my freaken car's a hover craft...im sorry but this is really aggravating any help would be much appreciated...would a camber kit fix the problem???
Old Mar 18, 2006 | 02:28 PM
dc2vu's Avatar
something is extremely wrong..all integra and civic and del sol brakes/suspension is basically the same...a camber kit will not fix this issue
Old Mar 18, 2006 | 03:07 PM
highroller54's Avatar
Default Re: (dc2vu)
what year of teggy?
Old Mar 18, 2006 | 03:46 PM
Slamaccord's Avatar
Default Re: (highroller54)
You must of used 90-93 integra knuckles.
You should used the 94-01 knuckles i believe......Correct me if I'm wrong
Old Mar 18, 2006 | 03:55 PM
i really dont know what year it is from....i hope its not the 90-93,,,,than i would have just gotten screwed...i looked at my friends 94 integra today and noticed it was a lil bit different from mine....on mines it has this little cover that you unbolt to 10 mm and it covers the crown bolt and cotter pin of the upper ball joint....he didnt have this piece on his integra...HELP!!!!!
Old Mar 18, 2006 | 05:00 PM
Default Re: (eg2phosizzle)
the 94+ teggy upper control arms are the same as the delslows, if yours are different then you got the wrong year!
Old Mar 18, 2006 | 05:52 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg2phosizzle &raquo;</TD></TR><TR><TD CLASS="quote">i really dont know what year it is from....i hope its not the 90-93,,,,than i would have just gotten screwed...i looked at my friends 94 integra today and noticed it was a lil bit different from mine....on mines it has this little cover that you unbolt to 10 mm and it covers the crown bolt and cotter pin of the upper ball joint....he didnt have this piece on his integra...HELP!!!!!</TD></TR></TABLE>
This is a characteristic of 90-93 Integra front spindles. The 94-01 Integra, 92-95 Civic, and 93-97 Del Sol don't have this.
Old Mar 18, 2006 | 06:03 PM
hatchi's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
This is a characteristic of 90-93 Integra front spindles. The 94-01 Integra, 92-95 Civic, and 93-97 Del Sol don't have this.</TD></TR></TABLE>
+1
Old Mar 18, 2006 | 06:08 PM
yeah maybe you're right but the thing was i bought brake hardware and new brake pads for the spindles and they fit perfectly..i just checked the part numbers for the brake pads and they were different part numbers so i am really confused about this problem...
Old Mar 18, 2006 | 06:09 PM
90-93 were different part numbers from the 94-01
SoTexDC2
Sep 18, 2009 01:19 PM
remedyz12965
28
Apr 7, 2008 02:04 PM
saveacivic
Sep 14, 2007 06:17 PM
asmallsol
Apr 16, 2004 06:13 AM
