b16 injectors
Old Mar 18, 2006 | 11:21 AM
dkk119's Avatar
Default b16 injectors
i was wondering what injectors the b series uses, saturated or peak and hold from the factory, and if using peake and hold would i have to change the resistor box with every different application?
Old Mar 18, 2006 | 11:26 AM
Spracer03's Avatar
all B-series and D-series use 240cc Saturated injectors... you can use peak and hold Prelude injectors if you wire up a resistor box
Old Mar 18, 2006 | 11:31 AM
dkk119's Avatar
Default Re: (spracer03)
would it be better to go with a peak and hold or a saturated on a turbo setup?
Old Mar 18, 2006 | 11:36 AM
Spracer03's Avatar
id just get the higher cc injectors to work with the factory system, i think most people only do the saturated > Peak n hold conversion to use lower priced oem injectors from other cars ie:DSM injectors. Just buy saturated RC's if you got the money
CaliforniaDad
Aug 14, 2011 01:55 AM
boost_is_best
Feb 28, 2006 03:45 PM
hondaaccord94
Jan 16, 2006 06:55 PM
MaaseyRacer
Sep 3, 2003 11:42 AM
DelsolVtec18
Oct 5, 2001 03:56 PM
