Suspension & Brakes Theory, alignment, spring rates....
Do i need anything else?
Old Mar 18, 2006 | 10:58 AM
Jxi8s2k's Avatar
Default Do i need anything else?
i'm planning to drop my ride using ground controls and koni yellows. inorder to go through with this, would i need to purchase any other minor parts? i dont' want to order everything and be excited just to find that i need to buy other parts.
Old Mar 18, 2006 | 03:43 PM
Voyage34's Avatar
Default Re: Do i need anything else? (Jxi8s2k)
an alignment but other than that i think youre set
Old Mar 19, 2006 | 02:58 PM
Jxi8s2k's Avatar
Default Re: Do i need anything else? (Voyage34)
i can use the stock bumps and top hats?
Old Mar 19, 2006 | 03:21 PM
rockdude14's Avatar
if you really want to be prepared
buy new lca bolt for the shock
and new lca shock bushing
most have to cut them out
good choice on koni and gc
Old Mar 20, 2006 | 02:48 AM
Jxi8s2k's Avatar
Default Re: (rockdude14)
where can i get them and how much do they run at? also..i'm not planning to get a camber kit. that will be ok right? just get the toe to zero?
Old Mar 20, 2006 | 08:36 AM
fokai's Avatar
PB Blaster
Spring Compressor
Old Mar 20, 2006 | 09:21 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (guam)
You won't need a camber kit. Just get that alignment to zero out the toe. This will save your tires in the long run...
A very important step after lowering that is often overlooked is "reseting all your suspension bushings". This relieves the twist in the bushings that will occour once you set the car back on the ground. It helps prolong the life of your suspension bushings greatly...
1. jack front of car up & place on jack-stands
2. place jack underneath one LCA
3. jack up LCA until car barely lifts off nearest jack-stand
4. loosen all bolts in that corner of the suspension that go through the center of a bushing
5. torque all bolts back down to their specific value listed in factory service manual
6. lower LCA down & move jack to other side
7. repeat steps 3-5 on other side
8. move to rear of car & repeat steps 1-7 & your done.
Do this before you get an alignment otherwise you will have to get another one...
One more tip: use anti-sieze goo on all your rear LCA bolts (threaded & non-threaded portions). The non-threaded parts of those bolts tend to rust solid to the inside of the bushings making them impossible to remove w/o cutting (as mentioned before). If you break a bolt head off (as I did), your going to have a hell of a time finding someone to help you cut it off & fix it. A good Honda mechanic should know exactly what to do if this happens (it is VERY common)...
Old Mar 21, 2006 | 02:42 PM
Jxi8s2k's Avatar
Default Re: (94eg!)
cool. thanks man.. the list you just typed up..is that a how-to on ressetting the bushings? i have access to a lift so i'm not gonna need jacks.
Old Mar 21, 2006 | 06:36 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (Jxi8s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jxi8s2k &raquo;</TD></TR><TR><TD CLASS="quote">is that a how-to on ressetting the bushings?</TD></TR></TABLE>
Yes
PowerPig
Suspension & Brakes
19
Mar 26, 2009 11:41 AM
CAN97SH
24
Mar 15, 2007 02:54 PM
JDR
Suspension & Brakes
Jun 21, 2005 11:30 AM
dread
Oct 16, 2003 11:37 AM
milanoGS-R
May 23, 2003 11:32 AM
