ABS Axels on Non ABS car?? HELP!!
Hey guys just wondering. I have a 92 EG si with a b18c1 motor from a 95 teg. My drivers side axel needs to be replaced and the only ones i could find were 95 GSR ABS axels. I should be able to use them right? I thought the only difference was that little ring with teeth on the axle cup. Also just to make you do use 94-01 axels on an EG swap right?? Thanks Again...
philosofy1
Oct 26, 2005 02:08 PM
