HELP!! boosted msd ignition problems - sputtering.. dying..
Old Mar 17, 2006 | 11:47 PM
92lstcvc's Avatar
Default HELP!! boosted msd ignition problems - sputtering.. misfiring.. cutting out~
recently my 300hp b18b turbo civic has been giving me some troubles
ONLY at a constant rpm or high end rpm, will it misfire a little
after moderate misfiring the engine decides to die - this has happened three times.. - i let the engine sit a while and she fires up again
MOST of the time she works perfect ..
the stock distributor was modified for a msd blaster 2 external coil
the coil wire isnt in its best condition and the dissy terminal is rather ghetto/loose and im wondering if that would be the problem??
i have a new msd distributor cap, msd rotor, spark plug wires, and ngk bkr7e's on the way...
Modified by 92lstcvc at 10:09 PM 3/18/2006
Old Mar 18, 2006 | 09:09 PM
92lstcvc's Avatar
Default Re: HELP!! boosted msd ignition problems - sputtering.. misfiring.. cutting out~ (92lstcvc)
Xtreme_Cause
18
Jun 22, 2020 08:27 AM
importdps
50
Nov 15, 2008 03:38 PM
importdps
92lstcvc
Mar 19, 2006 07:00 AM
CruiseControl
Dec 9, 2005 10:40 PM
