***How-To*** Polish A Header
Tools Required:
- Mothers Aluminium Polish or another type of metal polish
- 800 grit & 1000grit sandpaper
- Soapy water
- 2 rags/cloths
- Old Newspaper
- Roll of paper towel
- Brake Cleaner
Optional:
- Latex gloves (to keep your hands clean)
- Tooth Brush
- Rust cleaner
Not pictured are the paper towel roll, tooth brush and bucket of soapy water.
1) First you start off by cleaning up the header as best as you can. I did this by using the soapy water and a rag/cloth to wipe most of it clean. Then I dipped my tooth brush into the soapy water to get the hard to reach places like in-between the collectors.
2) After you’re done cleaning the header, rinse of the header with water and proceed to dry it with the paper towel. Since I wasn't looking to get the header perfect I moved on to the next step. If you want the nicest shine possible or your header is rusted to ****, this is where you grab the rust cleaner and repeat step one using the rust cleaner instead of the soapy water. Once finished with the rust cleaner repeat step one again with the soapy water solution.
3) No find a place where you’re going to start the labour intensive work or sanding down the header. Take your old newspaper and spread it out over your work area.
4) Now after the finding your place to work put your gloves on. Then grab your brake cleaner and spray a clean rag/cloth or paper towels and wipe down the header. This should get all the parts you missed before with the soapy water solution clean.
5) Now grab your 800 grit sandpaper and rip it into four equal pieces. This makes handling the sandpaper a lot easier. Begin to work away at the rusted header. Once you start to see the sandpaper get clogged up, give it a quick rinse to clean it out. Repeat this step for the whole header until most of the difficult rust is gone.
6) Now to make things go a little faster, a trick I picked up detailing. Spread the metal polish over the part of the header you'll be working on like so. Make sure not to over apply the metal polish. In the picture below I used that amount for the front of that collector I was working on.
Then grab your 1000 grit sandpaper and again rip the sandpaper into four equal pieces. Then use the sandpaper together with the metal polish to get your desired results quicker. This way is faster than just using sandpaper alone; like so.
Your sandpaper will get clogged up and the metal polish will turn a rusty brown colour. Don't worry just rinse out your sandpaper or grab a new piece. Then wipe off the old metal polish with your paper towel and add some more metal polish to the header. Remember not to over apply the polish.
This is what collector # 4 looks like after this process. It took me about 30 - 45mins. Just make sure to take your time.
7) Now repeat step 6 again for the rest of the header. This is me moving on to collector # 3.
This is how my header looked after about 3 hours of work. Yes I skipped collector # 2 just because it was the hardest one, so I did that last.
8) Once you’re done with the sanding/polishing of the header, clean it again with your soapy water and give it a good wipe down with your rag/cloth or paper towels.
9) Then give it a good rinse with some water
10) Now if the header is looking good to your satisfaction, re-install it on your car and skip to step # 16.
11) If not grab your sandpaper and give the header another light scuffing. Like so:
How the header looked after the light scuffing
12) Grab another rag/cloth and get to work with the metal polish working it into the header until you get the shine you want. It will not shine like chrome so; do not get your hopes too high. Remove any excess polish with paper towel.
How the header looked after polishing collector # 1. (Closest to the top of the picture) The other three collectors untouched by the polish.
How it looked after all the header was polished
13) Give it a good wipe down with soapy water once again
14) Rinse it off for the last time before installing it on your car
15) Dry off the remainding water on the header. This will be your finished product.
16) Once re-installed on the car BEFORE starting the engine, grab your brake cleaner and spray the entire header down with it. Then spray some brake cleaner onto some paper towels and give the header a final wipe down, making sure to wipe everything. You do this because the oils from your hands will cause the header to discolour unevenly, once the engine is started. You do not want this. You want it to turn a nice even bronze after a couple kilometres of use.
Before:
After
Pics of the header on the car after driving
Good Luck
Modified by wildoutwhitegsr at 4:08 PM 5/21/2006
- Soapy water
- 2 rags/cloths
- Old Newspaper
- Brake Cleaner
Optional:
- Tooth Brush
- Rust cleaner
Before:
After
Good Luck
Awesome expletiven write up, could not have come at a better time, cuz i just so happen to be buyin a used header that looks exactly like that and now its gonna look good, and it seriously would not have if you hadnt did this...
for you... you should get an extra point for this... hint to mods
Nice.
When I put my header on, it turned that nice blueish color for awhile,
Not three months later its kinda got small round cuircles that look like rust, but its brown. and wont wipe off.
So, I think I might do this. and then spray from VHT Header Paint Clear Coat on it.
