Does EG6 Struts/Shocks fit EF8?
Old Mar 17, 2006 | 09:38 PM
hmtcrxsir's Avatar
Default Does EG6 Struts/Shocks fit EF8?
Just wanted to know if EG6 strut/shocks will fit EF8?
Old Mar 17, 2006 | 09:47 PM
Jokerluv's Avatar
i put 91 hatch springs on my 95 vx lowered it 1 inch
Old Mar 17, 2006 | 09:48 PM
hmtcrxsir's Avatar
Default Re: (Jokerluv)
what i meant was will the 95 civic coilovers/shocks fit the 88-91 crxs?
Old Mar 17, 2006 | 11:04 PM
FalkenSiR's Avatar
Default Re: (hmtcrxsir)
They will, just the 88 Civics/CRXs rear LCA is different. The fronts will fit, not the rears. So basically 89-91.
Old Mar 17, 2006 | 11:53 PM
beelzebub's Avatar
Default Re: Does EG6 Struts/Shocks fit EF8? (hmtcrxsir)
Both EG and EF suspension are interchangable (except for 88 that uses ITR RLCA). If using EG suspension on EF, use EG front forks, vise versa for EF on EG.
Old Mar 18, 2006 | 02:14 AM
hmtcrxsir's Avatar
Default Re: Does EG6 Struts/Shocks fit EF8? (beelzebub)
thanks
Old Mar 18, 2006 | 02:15 AM
hmtcrxsir's Avatar
but the back suspension is just a bolt in process right?
Old Mar 18, 2006 | 09:09 AM
beelzebub's Avatar
Yes it's bolt in unless you have an 88 civic/crx. Otherwise straight forward swap.
Old Mar 18, 2006 | 09:27 AM
SVOboy's Avatar
So I can actually use EG shocks in my ef if I have the eg front forks? I always thought the CRX was unique about it's crap, oops,
Old Mar 19, 2006 | 07:46 PM
beelzebub's Avatar
Default Re: (SVOboy)
Yes, that is correct.
724chris
Dec 16, 2009 10:47 PM
lonefuzzy79
Nov 19, 2005 02:06 AM
Don Johnson
Aug 31, 2005 05:20 AM
GrossmeisterB
Jul 4, 2004 07:24 AM
iceboy
Sep 15, 2003 09:42 AM
