Trottle body's????
Old Mar 17, 2006 | 07:52 PM
slixxracing's Avatar
Default Trottle body's????
I have a skunk2 manifold, w/ a 92 LS trottle body at the time being. I have extra coolant hoses that are open so I just stuck a tube and plugged it with a bolt at the end of the tube.
If I was to use the trottle body as pictured below
How would I go about plugging up all the necessary holes up?
There are
1 from the upper radiator holes that supposed to go to one of the inlet of the tb. If im correct?
1 that is by the fan switch/header hose from the fire wall
and the last one is on the skunk2 manifold itself that has a 1/4" outlet and a smaller one together on hose stick?
any help will do.
thanks
[BEDITED[/B] - Also, w/out the cold start unit on the bottom of the trottle body (cause the cold start portion is on the LS intake manifold itself) would the car idle bad when cold? Which trottle body would have a colt start unit attached to the trottle body? The unit I am talking about are these ones below w/ the 2 hose ends for coolant to pass. Are these trottle body gsr's?? Can anybody tell?
Modified by slixxracing at 11:49 AM 3/18/2006
Modified by slixxracing at 11:50 AM 3/18/2006
Modified by slixxracing at 11:51 AM 3/18/2006
Old Mar 18, 2006 | 10:51 AM
Default Re: Trottle body's???? (slixxracing)
Any information?
Old Mar 18, 2006 | 12:23 PM
97grnrs's Avatar
eliminate any unnecessary hoses.. i dont run coolant through my TB at all. i basically found where the coolant like starts on the mani or whatever and just looped it back to the side where it supposed to drain back into the motor.. i did it for iacv and the TB. i bypassed my iacv also and the FITV on the Tb.
Old Mar 19, 2006 | 10:38 AM
Default Re: Trottle body's???? (97grnrs)
By doing that, wouldn't it affect the cold starting idle?
Old Mar 19, 2006 | 02:03 PM
SkankyEJ7's Avatar
i didnt mine like that, i wouldnt know how it messes with idling, i think i have a vaccum leak
Old Mar 19, 2006 | 07:35 PM
Default Re: Trottle body's???? (98ekhx)
because the bottom portion of the trottle body (if it came with it) controls the cold start idling problems. w/out it when cold, shouldnt your idle be as if you had wild cams in?
waynesumner
28
Feb 12, 2026 03:51 PM
civics4lyfe
Jun 7, 2015 12:44 PM
90LSpimpin
Feb 3, 2005 07:19 AM
57one
Mar 2, 2003 03:36 PM
