Cata Converter bolt HElp !!
so i got a 91 teg 2dr, changing the headers on it, and the bolts connected to the down pipe and the cata converter are welded, and i tried basically everything to get them off... saw, hammer, tried unbolting (lol) just wont budge and its the LAST BOLT i need to replace the header
any one got any ideas ??
thanks
thanks
I had the same problem on my 93 Teg I ended up grinding the nut off and then I noticed the Bolts were pressed in and welded I ended up drilling out everything and just using bolts now
ok so ..
I got the new headers on... BUT
it rubs againist the oil pan, do u think it will tear a hole in it ?? or should I put a thin peice of metal in-between it so it wont heat it up ??
and it makes like a ricey sound now, around 1-3K rpms, but after that a deep sound...
Help and thx !!
Help and thx !!
