low beams
Old Mar 17, 2006 | 05:25 PM
freeway's Avatar
Default low beams
They are H4s right?
Old Mar 17, 2006 | 05:33 PM
freeway's Avatar
Default Re: low beams (freeway)
I think the manual says HB4. Ive seen HBs and H4s for sale.
Old Mar 17, 2006 | 05:35 PM
kuja's Avatar
uhh, for a usdm integra? aren't they 9006
Old Mar 17, 2006 | 05:36 PM
freeway's Avatar
shaft. I have no idea now.
Old Mar 17, 2006 | 05:37 PM
kuja's Avatar
Default Re: (freeway)
i know for a fact the low beams are 9006.. Sorry i had to think for a second. Threw me off with the h4 shiat ;D
Old Mar 17, 2006 | 05:45 PM
freeway's Avatar
Default Re: (kuja)
here's what my manual says.
Old Mar 17, 2006 | 05:48 PM
kuja's Avatar
OHH, dur. My bad, I didn't even see that you mentioned Hb4 in your post.. HB4's are 9006, and HB3 is 9005.. So ur all good..
freeway's Avatar
are you sure? 9005s then. Thanks.
Old Mar 17, 2006 | 05:50 PM
kuja's Avatar
yes sir.
Old Mar 17, 2006 | 05:57 PM
OMG THE GOGGLES's Avatar
Default Re: (kuja)
Trust team-integra.net
http://www.team-integra.net/se...D=512
its a 9006
Old Mar 17, 2006 | 05:59 PM
kuja's Avatar
Default Re: (gasper44`)
9005/HB3 if your going to be doing the conversion. If not 9006/HB4, Sorry if i'm confusing you. But if you just want a stock replacment bulb its a 9006. But alot of people put the 9005's in with slight modification.
Old Mar 17, 2006 | 07:49 PM
db8gsr_teg's Avatar
Default Re: (kuja)
i think 9006 are for low beams and 9005 are for high beams
Old Mar 17, 2006 | 07:55 PM
rufridn's Avatar
Default Re: (db8gsr_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8gsr_teg &raquo;</TD></TR><TR><TD CLASS="quote">i know 9006 are for low beams and 9005 are for high beams </TD></TR></TABLE>
fixed
Old Mar 17, 2006 | 07:59 PM
xkrntamax's Avatar
98 year model used 9005 as high beam
and 9006 is low beam
Old Mar 17, 2006 | 08:12 PM
.brian.'s Avatar
Default Re: (xkrntamax)
you can use the 9005 as a type of "retro fit" and should have no problems.
there are a few threads that tell you how to do this, it is pretty simple. jsut search for "9005 9006" and make sure you search archived and you should find some.
Old Mar 18, 2006 | 12:08 PM
integra racr04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8gsr_teg &raquo;</TD></TR><TR><TD CLASS="quote">i think 9006 are for low beams and 9005 are for high beams </TD></TR></TABLE>
Old Mar 18, 2006 | 04:32 PM
gsr dood's Avatar
Default Re: (integra racr04)
DEF 9006 just got hids i 9006's for my 94 gsr fit perfect
Old Mar 18, 2006 | 05:34 PM
Gerbilo's Avatar
Default Re: (gsr dood)
Check my signature for a 9005conversion howto I wrote a while back. I'm stickin with it for now since I don't feel like paying for HIDs. It seems to work well, but I do have to replace the bulbs once a year or so, it doesn't help that i'm using silverstars though.
articsilber323
Lighting
Sep 18, 2009 05:28 PM
Bimmerman
63
Dec 7, 2005 04:52 PM
2001LS-R
Dec 4, 2003 03:09 PM
The Poopsmith
Nov 24, 2002 07:58 AM
Wet Nudl
Feb 20, 2002 10:44 PM
