I messed up and need help
Old Mar 17, 2006 | 04:33 PM
Civicracer17's Avatar
Default I messed up and need help
While changin the axle on my car I did what people told me not ti do and hit a bolt with a hammer... now it mushroomed and I cant get nut on it... How can I fix it?
Old Mar 17, 2006 | 04:37 PM
pro1342's Avatar
without a tap/dye set, the easiest way is to file or grind the end of the bolt down until you can get the nut to slide on, and then try to get the nut to start threading
Old Mar 17, 2006 | 04:57 PM
chimves's Avatar
i wouldnt be the most conserned about the nut side i would check the tranny side or half shaft for possible damage first. are they in place?
Old Mar 17, 2006 | 04:59 PM
Default Re: (chimves)
what do you mean? the Axle is in it was the Bolt for the Tie rod I think
Old Mar 17, 2006 | 05:00 PM
Diego Dangers.'s Avatar
get a set of thread repair files. they work wonders on axles.
Old Mar 17, 2006 | 05:06 PM
Default Re: (Diego Dangers.)
everyone knows it wasnt the Axle I messed up
Old Mar 17, 2006 | 08:56 PM
jdmsiR20's Avatar
Default Re: (Civicracer17)
so u messed up the lower ball joint stud, correct?
dammit, we had that problem too. ended up getting a new ball joint... i tried cutting and filing it down... and a tap and die set, to no avail. doesn't mean you cant try
Old Mar 18, 2006 | 06:56 PM
Default Re: (jdmsiR20)
JDMsiR20 you online??? you got AIM or yahoo?
Old Mar 19, 2006 | 07:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicracer17 &raquo;</TD></TR><TR><TD CLASS="quote">everyone knows it wasnt the Axle I messed up</TD></TR></TABLE>
regardless, thread files work for all kinds of threaded stuff. aka, your ball joits.
Old Mar 19, 2006 | 08:30 PM
vinai's Avatar
his aim sn is his ht name
Old Mar 19, 2006 | 08:33 PM
TRE_'s Avatar
Default Re: (vinai)
i did this once while lowering a car,, stupid mistake and ended up being a pain in the ***. tried to fix it every way we knew how and nothing worked. had to buy a new ball joint... try napa, they usually sell them for fairly cheap.
iwanttogofast
Jan 31, 2007 03:22 PM
91zSi
30
Aug 4, 2005 04:09 PM
yh23
25
Jun 15, 2005 08:47 AM
tuphatt
11
Sep 15, 2004 12:10 AM
Rod.
Jan 23, 2004 09:11 PM
