TESTING waters: BUILT D series and other parts
Old Mar 17, 2006 | 03:56 PM
joshb_'s Avatar
Default TESTING waters: BUILT D series and other parts
Testing the water here.....I think im going to turbo my 04 civic instead of the 89 hatch due to title isuses so here it goes....
D16a6 bottom end...
All machine work done by TW machining in Fairport NY....known for expensive but good work
-20 over bore and block notched then acid tanked
-wiseco 20 over z6 pistons with 8.5:1 comp
-Eagle rods (newer ones with the arp 2000 bolts)
-acl std bearings and thurst washers
-Oem water pump, oil pump, front and rear main seals, oil pickup gasket timming tensioner (everything on the motor is new)
oem oil filter
D16z6 head
I spent 3 hours cleaning this things ports and valves, combustion area
Oem valve seals
6/1000 valve spring shims to get 14lbs more spring to the oem springs (can rev to 8000rpm with pretty much no worries)
Zex comp 59300 cam
Plastic intake mani gasket
z6 manifold
b16a TB
D16Y valve cover painted a "mugen" grey color with the honda left silver and new oem valve cover gasket
z6 dizzy
rx-7 550 cc injectors
ALL this for 1300 dollars the motor has zero miles and has never been started
Also for sale
91 Si cable tranny with clutch specalites 4 puck unsprung clutch...300 dollars
92-95 intake side charge pipes with blitz bov tiged on..120 dollars
PO6 ecu chiped with crome pro..100 dollars
Hotrex mini ram manifold with external gate flange 38mm....260 dollars
more to come...with pictures being uploaded right now
Old Mar 17, 2006 | 04:40 PM
MAFDARK's Avatar
Default Re: TESTING waters: BUILT D series and other parts (joshb_)
good seller, and all good ****
Old Mar 17, 2006 | 05:44 PM
joshb_'s Avatar
bump
Old Mar 17, 2006 | 08:44 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Default Re: (joshb_)
good guy to deal with
Old Mar 19, 2006 | 10:25 AM
joshb_'s Avatar
Old Mar 19, 2006 | 03:17 PM
joshb_'s Avatar
All sold to a kid loacally
navz121
Jun 20, 2011 08:50 PM
OrangeTeggy
Apr 25, 2011 10:29 PM
Hill4589
Northeast (Sales)
10
Oct 7, 2010 03:08 PM
MONSTERek4
Jan 7, 2010 12:14 PM
ranta18
Mar 13, 2004 09:58 PM
