what kinda spark plug do i run with a turbo set up
Old Mar 17, 2006 | 02:55 PM
willie_d18's Avatar
Default what kinda spark plug do i run with a turbo set up
i got a d16y8 stockmotor. with a turbo set up ready to install. but i know people say to get colder spark plugs. i usally run denso iridium plugs. with the msd set up. what do i suppose to do.
Old Mar 17, 2006 | 04:04 PM
trooper0641's Avatar
Default Re: what kinda spark plug do i run with a turbo set up (willie_d18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willie_d18 &raquo;</TD></TR><TR><TD CLASS="quote">i got a d16y8 stockmotor. with a turbo set up ready to install. but i know people say to get colder spark plugs. i usally run denso iridium plugs. with the msd set up. what do i suppose to do. </TD></TR></TABLE>
Go to Kragens and order NGK BKR7E and gap them to about .28-.30 and boost. The 7 in BKR7E is the rating of the plug. Stock is 5, 6 is for intense N/A applications and 7 is for boost...8+ is for people who are crazy. Im not going to give you anymore info! Research lazyasses!
Old Mar 17, 2006 | 05:03 PM
flood's Avatar
Default Re: what kinda spark plug do i run with a turbo set up (poison)
when you go to get them remember that NGKs the higher the number the colder. I think other plug makers are opposite.
if you go to NGKs website they have some good info about plugs.
Old Mar 17, 2006 | 05:20 PM
posite's Avatar
agreed. ngk bkr7e gapped to .3 is going to be your best bet and go from there.
Old Mar 17, 2006 | 05:43 PM
axtran's Avatar
best luck i've had in the past with FI is using copper 7 series NGK. so i put in a vote for these BKR7Es too!
ChadB
May 16, 2012 07:43 PM
willie_d18
Mar 29, 2006 10:44 PM
sleepystyle
Mar 29, 2006 07:50 PM
Devo94ac
Nov 2, 2005 08:53 AM
Brian_92GSR
Jan 17, 2002 07:01 AM
