Problem with my blinkers
Old Mar 17, 2006 | 10:30 AM
Jameson's Avatar
Default Problem with my blinkers
I was driving my car and my blinkers stopped working. My hazards will work but not the blinkers. Could it be a fuse or loose wire? Any help would be great.
Old Mar 17, 2006 | 10:45 AM
Jameson's Avatar
Default Re: Problem with my blinkers (Jameson)
Someone please help!!! I need to know asap so I can get my car inspected!!
Old Mar 17, 2006 | 10:48 AM
eumoria's Avatar
it may be as simple as the connection to the switches.
take off the steering wheel and that black plastic column cover to look at the switch and harness attached. pull and reseat those connections then check all the fuses.
also depending on the year of the car you can flip the blinkers manually on the switch not using the stick, make sure that the steering reset thing is set up right when you put it all back together or else when you're done completing a turn your blinker won't click off.
if you still have problems your next step would be to pick a multimeter and find where the power is getting dumped
Old Mar 17, 2006 | 10:55 AM
Jameson's Avatar
Default Re: Problem with my blinkers (eumoria)
Cool thanks alot man!
LanayAllDay
Nov 3, 2010 10:13 AM
_Spugen_
Oct 8, 2004 06:09 PM
mrcch
Dec 15, 2003 08:56 AM
pablo_max
Nov 12, 2002 04:02 PM
