help! JDM H22 surging under low load, 2-3.5k rpms
Old Mar 17, 2006 | 10:29 AM
-DC2-'s Avatar
Default help! JDM H22 surging under low load, 2-3.5k rpms
i figure you prelude guys know the most about the H22
here's the car/setup:
https://honda-tech.com/garage?cmd=viewcar&id=4520
the symptoms:
- idle is rock solid at 1k
- hold throttle in neutral at 2k rpms, and the car surges from 1700-2200, up and down
- car surges when cruising on highway at 65mph (annoying as ****!)
- NO CELs
what i've ruled out:
- there's no vaccum leaks (idle is rock solid)
- o2 sensor is fine cause it does it in both open and closed loop (forced thru crome)
- replaced TPS, MAP
any ideas?
at this point i would guess it's in the fuel/timing map. car is not tuned yet.
smkelly1
Oct 23, 2012 04:04 PM
hkarmy
Oct 21, 2009 01:12 PM
dahoopdahup
Mar 21, 2006 04:30 PM
lcaruca97
Oct 3, 2003 05:48 PM
