LOOK HERE WIRING GURUS. I need help finding out what these plugs are
Old Mar 17, 2006 | 10:04 AM
b.d.racing's Avatar
Default LOOK HERE WIRING GURUS. I need help finding out what these plugs are
I'm getting close to being done wiring up the whole car but I've got a few questions as to what is what.
Picture A
1.)What is the plug below the yellow one?
2.)What is the plug at the bottom of the picture where the pedals are?
3.)What is the plug under the right nut that holds up the fuse box?
Picture B
1.)What is this plug?
Picture C
1.)What is this plug coming off the ignition harness?
Picture D
Which plugs off the dash harness correspond to the other pics?
Thank you. Any help is much appreciated.
Old Mar 17, 2006 | 10:46 AM
eumoria's Avatar
Default Re: LOOK HERE WIRING GURUS. I need help finding out what these plugs are (b.d.racing)
are you just putting the wiring back in the same car it came from?
what year/model is it? the ignition harness differs from the 88-89 models to the 90-91 and the harness will also be different if you have intermittent wipers. I'm sure someone with more 88-91 experiance may know just from looking.
Old Mar 17, 2006 | 11:40 AM
b.d.racing's Avatar
Default Re: LOOK HERE WIRING GURUS. I need help finding out what these plugs are (eumoria)
No I'm putting a wiring harness back in the car from scratch. I have nothing to go off of but memory. This is an 88-89 harness although I'm hearing from a local junk yard that 88 is different from all the other years. I'm also not running any wipers. Anybody please help me out.
Old Mar 17, 2006 | 11:43 AM
silentdork818's Avatar
A factory manual would be your best friend here. You can do anything with one of those.
Old Mar 17, 2006 | 01:54 PM
b.d.racing's Avatar
Default Re: LOOK HERE WIRING GURUS. I need help finding out what these plugs are (silentdork818)
Where do I get one of those manuals?
Old Mar 17, 2006 | 02:05 PM
You can find one on ebay for pretty cheap, if not your library *might* have them.
Old Mar 17, 2006 | 02:22 PM
doublethink's Avatar
PICTURE C
is your column mounted hazard switch.
if your running a 90-91 dash you need to cut and extend these wire to the cluster hood since thats where the hazard switch is located on those cars.
thats why youll usually see poeple suggesting to match the year if you do a wire harness swap.
if you removed this harness and its going back into the same car and you cant remember you probably should have taken a few pictures.
the plugs near the fuse box dont change, and are all uniquly shaped, honda is good like that.
so you cant cross plugs under there, so in other words for every female unused youll have a corresponding male, or a switch that uses it.
Old Mar 17, 2006 | 03:21 PM
Chase's Avatar
Default Re: LOOK HERE WIRING GURUS. I need help finding out what these plugs are (doublethink)
A- I dunno, sumthin
B- That looks familiar, like the plug for the Heater core or the fan.
C - looks like what double think said
D- I dunno
Old Mar 17, 2006 | 03:53 PM
RCautoworks's Avatar
Did this last week, its the cluster wiring correct ? I circled the spots where the plugs should go
Old Mar 17, 2006 | 06:30 PM
wood's Avatar
Default Re: LOOK HERE WIRING GURUS. I need help finding out what these plugs are (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Did this last week, its the cluster wiring correct ? I circled the spots where the plugs should go
</TD></TR></TABLE>I don't see the cluster wiring. Get a manual, it will be a huge help.
Old Mar 17, 2006 | 09:47 PM
Broke EF's Avatar
Default Re: LOOK HERE WIRING GURUS. I need help finding out what these plugs are (wood)
Ok as far as I know this is how it goes.
The other 2 plugs Im not sure about, I never saw those on my 91 Hatch.
Hope this helps a lil.
Sean
Old Mar 18, 2006 | 01:07 AM
bigcalidave's Avatar
Like the other guy said, no two plugs will fit in the same spot! Just plug everything in and there ya go.
Old Mar 18, 2006 | 05:20 AM
92 si hatch's Avatar
if you find an empty socket, try to plug it in. If it works then, bingo. Might I suggest a manual though. They always come in handy
GrimLude
May 13, 2014 11:24 AM
woodenchef
17
Jul 14, 2013 10:09 AM
alacard
Jan 8, 2009 06:06 PM
GripFactoR
Nov 21, 2003 02:36 PM
slow hatch
Dec 22, 2002 07:30 AM
