HELP ABS LIGHT ON HELP
My ABS light is on what can I do?
I took my car to Good Year for a brake fluid flush and a month later my brake fluid is below level? They forgot to tighten a hose and they fixed that. Today I noticed that my ABS fluid was below level so I filled it back up but the light didn’t go off. I think GY fucked my car up but I know 5th gen accord have ABS problems
i checked the fuses are they are good
i checked the code and it was 18
what is 18?
Thank you for your time
Modified by businessmanph at 1:58 PM 3/17/2006
what is 18?
http://www.bba-reman.com/conte...codes
it says it's the Pressure accumulator
what is that and how do i fix it
i checked out helms and it said i need to
replace the modulator unit
-accumulator gas leakage
-relief valve set pressure out of spec
-rear outlet solenoid vavle late to close
-pressure switch set pressure out of spec
i don't even know what this means help please
sometimes when i turn the car on the abs light stays on and sometimes it does not.
Modified by businessmanph at 5:00 PM 3/17/2006
