Help with wiring
Old Mar 17, 2006 | 08:51 AM
dagimp415's Avatar
Default Help with wiring
I'm having trouble with the wiring and i can't find any helpful links. I have a B18B OBD1 in my CRX and i'm ready to wire it up, but its my first swap and i'm having trouble. I have a stock PR4 ECU, do i need to chop the harness and wire it together with any of the stock CRX harness? also, will the interior harness clip into the ECU, any help would be much appreciated, i need this motor to start up by next thuresday. Thanks in advance -Justin
Old Mar 17, 2006 | 08:53 AM
si0385.'s Avatar
Default Re: Help with wiring (dagimp415)
obd0->obd1 conversion harness plugs right in
Old Mar 17, 2006 | 10:20 AM
dagimp415's Avatar
any other options, i'm tight on cash and odn't have much time.
Old Mar 17, 2006 | 10:54 AM
d16efsedan's Avatar
Default Re: (dagimp415)
other than making your own obo0-->obd1 conversion harness,i dont really see any other options...
Old Mar 17, 2006 | 11:34 AM
Maxximtl's Avatar
Default Re: (d16efhatch)
Save money and do it right. Believe me, wiring is not someplace you want to skimp. The previous owner of my car did some questionable wiring, and it is costing me $$ to try and fix it. Once you cut up your stock harness, there is no going back. The conversion harness is by far the best way to go.
Old Mar 17, 2006 | 12:24 PM
d16efsedan's Avatar
Default Re: (Maxximtl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maxximtl &raquo;</TD></TR><TR><TD CLASS="quote">Save money and do it right. Believe me, wiring is not someplace you want to skimp. The previous owner of my car did some questionable wiring, and it is costing me $$ to try and fix it. Once you cut up your stock harness, there is no going back. The conversion harness is by far the best way to go.</TD></TR></TABLE> agree'd unless your good with wiring.
NINETY2CIVIC
Oct 24, 2007 02:58 PM
^AnDre^
Mar 22, 2007 07:42 AM
spoink
Jan 5, 2006 10:51 AM
B20-Rex
11
Dec 17, 2004 08:37 AM
91teg
Sep 1, 2004 06:06 PM
