HOW TO CHECK TO SEE IF THEY STILL WORK!!!
Bought Precision injectors off a guy from ebay used AND now im wondering if they still work before i put them in and blow my newly boosted motor!
Is there a way to see if all are working properly?
also, he said they are 550cc but im kinda sure that precision makes 525 and something higher then 550. HOW DO I CHECK THE CC SIZS AND IF THEY ARE LOW/HIGH IMPEDANCE?
THANKS GUYS
THANKS GUYS
You can take them to a fuel injector place and have them test the injectors. Or you can hook them up to your rail and harness and try and start the car and see if the spray.
well im worried about 3 of the 4 working and im like OH the car started and is running
never did a comp. test. are you saying have the injectors in and pull the ecu fuse and then try to start the car?
freakasis
Jan 11, 2006 03:43 PM
igo4bmx
Sep 30, 2005 12:29 PM
