Excessive Oil Loss: Interesting find...
i believe that is my issue as well...i thought it was the oil pan gasket...but over the weekend i pulled the valve cover, and my oil seal on the intake cam was slighty towards the cam...i believe this is the culprit of my leak...i pushed it back in towards the motor and now seem to not leak as much...i've only put maybe 2 miles on the car since...but i'll be doing the same and replacing the bit$%...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitelightning »</TD></TR><TR><TD CLASS="quote">i believe that is my issue as well...i thought it was the oil pan gasket...but over the weekend i pulled the valve cover, and my oil seal on the intake cam was slighty towards the cam...i believe this is the culprit of my leak...i pushed it back in towards the motor and now seem to not leak as much...i've only put maybe 2 miles on the car since...but i'll be doing the same and replacing the bit$%...</TD></TR></TABLE>
....one word only....HONDABOND
Cam seals are a very common oil leak on the B18 motor. You can prevent this by adding extra hondabond around the oil seals on the valve cover and cam seals...
grease the inner lip that rides on the cam
hondabond the outer lip that rides in the head so it doesn't pop out
if it happens again
buy an endyn breather because you have too much crankcase pressure because its blowing out your seals.
if it happens again
drsab2000
Aug 8, 2015 05:47 PM
