When you bleed the coolant lines of air, what is the correct procedure?
I seem to remember a friend of mine said you start the car, then you fill the radiator up with the cap off, and let it run for a while, and watch for bubbles. I changed my radiator hoses today, and I think I've got air in my lines, because all of a sudden I have this loping idle problem, 1k to 2k rpms whenever the car is warm and in neutral.
Is that the correct procedure or do I have to do something different?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confusatron »</TD></TR><TR><TD CLASS="quote">I seem to remember a friend of mine said you start the car, then you fill the radiator up with the cap off, and let it run for a while, and watch for bubbles. I changed my radiator hoses today, and I think I've got air in my lines, because all of a sudden I have this loping idle problem, 1k to 2k rpms whenever the car is warm and in neutral.
Is that the correct procedure or do I have to do something different?</TD></TR></TABLE>
Definatly possible. With the car cold, take off the radiator cap. Top off with fluid and start the car. Continue to top off *** needed until the radiator fan kicks on at least once. (Both upper and lower hose should be hot now) Put cap on.
Thats it!
Thats it!
Louie_EM1
Feb 28, 2004 09:39 PM
cool
Dec 31, 2003 07:26 PM
