Stock header ok?
Old Apr 1, 2002 | 07:12 PM
Toretto's Avatar
Default Stock header ok?
Now that I have my CAI installed, I am looking into what I want to do next. I know I want to get a higher flowing exhaust, but not sure if I should get the cat back from Mufflers-n-More, and buy a Apexi Muffler, or just buy the whole N1 exhaust. As for the header, I have been hearing that the stock header, is 98% as good as the DC header, and is not worth replacing, so I am considering taking out my stock header, remove the rust, and painting it with some high temperature paint, so I can remove the ugly heatsheild. An easyway to give the aftermarket look, without the cost, and since performance wont really change with an aftermarklet DC header, looks is all what would change anyways. What do you guys think?
Old Apr 1, 2002 | 07:22 PM
typeSwarrior's Avatar
Default Re: Stock header ok? (Toretto)
DC makes crap headers. I know a guy who dynoed with the stock vs. DC and got worse results with DC. I say you got a good idea going. You could just paint the heat shield tho, make it *bling**bling* shiny.
Old Apr 1, 2002 | 07:29 PM
Toretto's Avatar
Default Re: Stock header ok? (typeSwarrior)
Hmmm, thats an idea that I will have to think about. I do think the header would look better though, i could try both I suppose. Thanks for the reply. Even if the DC header were to gain .5-1hp, thats not worth the 350 I would have to spend, when i could use that money towards cams, pulleys, nitrous, or anything of that kind.
Old Apr 1, 2002 | 08:09 PM
illusion's Avatar
wait for the sms header if its avail for 5th gen
Old Apr 1, 2002 | 08:15 PM
Honda318dx's Avatar
Default Re: Stock header ok? (illusion)
It will be available The only difference in the 4th and 5th gen is the legnth in the A pipe
Old Apr 1, 2002 | 08:50 PM
4bidden's Avatar
Default Re: Stock header ok? (Honda318dx)
the piping of the downpipe from my jdm h22 is larger than my greddy stainless that i ordered for it. i wonder if he accidentally gave me the type-s downpipe
Old Apr 2, 2002 | 06:17 AM
laughinxxx's Avatar
New User
The big *** collector and car sound cat will be nice when you are spraying or boosting.
Old Apr 2, 2002 | 07:01 AM
Greyout's Avatar
Default Re: Stock header ok? (laughin2.2)
I would leave the stock manifold & get a custom 2.5" collector made. a local shop quoted me $150 to do it, with a flexpipe.
Old Apr 2, 2002 | 02:34 PM
DYI01's Avatar
Default Re: Stock header ok? (JDM LUDE)
well from my experience the DC makes power, albeit not a whole lot of power, but it makes power. The primaries are larger then the stock manifold, but the collector is the same size. Now take the DC header and modify it like i did with a 2.5 in collector then it will make even more then a stock header, and a stock DC header for that matter. Add a high flow cat / testpipe, and a B-pipe flange adapter = NO BOTTLENECKS = more power.
Old Apr 2, 2002 | 03:32 PM
JinMTVT's Avatar
New User
Default Re: Stock header ok? (DYI01)
openning the connector makes the car more powerfull on the high rpm
but it always makes the torque curve rise more slower on the lower and low-mid rpm..
though the hole point of power is to get power in between 5800 and 7400rpm
spoon talks about that on their web site in the products downpipe ..
for b16/b18..but it's the same principle..
2.5" OD is the max i would ever go for any ehxuast part in the 5th gen with NA engine that does not want to go over 210-220 WHP ..
wass the price on the bigger cats ?
i think i'll find a way to bypass the cats and let the car go in open loop all the time..need to check out with the voltage required to do so ..
Old Apr 2, 2002 | 07:19 PM
Toretto's Avatar
Default Re: Stock header ok? (JinMTVT)
I picked up some high heat ceramic paint to paint the header, probably this weekend sometime. Is the header real hard to take off? I will think about either buying that sms header down the road, or having the stock header moded to flow better, it would probably be nice in the higher rpm's and when spraying.
Old Apr 4, 2002 | 10:39 AM
JinMTVT's Avatar
New User
the stock header is not mandrel bent on the upper parts..
it reduces somewhat some at some place..
but it's a really nice piece neway..
if you can afford to replace it with something like the SMS then go for it ..
but don't expect gains to give a WOW factor..you are talking in flow imporvement..
Old Apr 4, 2002 | 07:26 PM
Toretto's Avatar
I am mainly looking for looks improvement at the moment, because a better header isnt really needed yet. Is the SMS 4-1 0r 4-2-1? When is it going to be released and for how much?
Old Apr 4, 2002 | 11:59 PM
tim.simpson's Avatar
That's just what I have done! I removed the heat sheild to paint it with high temp paint, and wow that stock header ain't half bad lookin. I can't see its worth spending the money on a DC(that's all I could fund) that I won't notice any difference!
So, I have painted the heat sheild matt black (as it was) and painted the inside silver(to reflect heat back to the manifold). Then I decided that the colour looked good(sort of aluminium paint) on the inside, and I painted the outside the same.
Have refitted and it looks good! (Just have to wait for the smell of paint to go now!)
In the future, I have a club member(http://www.honda-r.org.uk) who is replacing his manifold on his Accord Type-R for a Mugen one, and I'm buying his Type-R stock manifold for mine!
Tim
[Modified by tim.simpson, 1:04 AM 4/5/2002]
[Modified by tim.simpson, 1:05 AM 4/5/2002]
Old Apr 5, 2002 | 07:05 AM
distuRbed's Avatar
how much gains can you expect from an aftermarket header approximately? thanks.
sonntag
Aug 14, 2012 01:25 PM
itrawesome
May 19, 2009 08:11 PM
team714
Jan 12, 2008 06:47 PM
Sic_DA_Nine
Dec 2, 2005 02:54 PM
