boost creep once it hits vtec, help out pls
Old Mar 16, 2006 | 06:35 PM
RedR's Avatar
Default boost creep once it hits vtec, help out pls
Ok so i installed a FR prostreet stage 1 turbo kit on my car along with a 3 inch exhaust, car is being tuned with hondata, but im having a boost creep as soon as the car hits vtec, i changed the wg spring for a new one (.5 bar) and it still happens, the boost cut at hondata is set at 9 psi.
I check the vaccum lines didnt find any leaks, any suggestion guys?
TIA
Old Mar 17, 2006 | 04:10 AM
RedR's Avatar
Default Re: boost creep once it hits vtec, help out pls (RedR)
help?
Old Mar 17, 2006 | 05:49 AM
99B16Si's Avatar
try a different vacuum source for your wastegate, and if youre using a small line with small fittings try using larger ones
jdecks23
Jun 24, 2017 10:09 PM
1320king
Engine Management and Tuning
Jul 7, 2013 11:01 AM
Lazysk8r2
Apr 6, 2013 09:28 PM
BlackThorN
Dec 21, 2003 12:51 AM
dwilson
Jan 23, 2003 09:48 AM
