OBD1/OBD2 Mixmatch!?!??!
Old Mar 16, 2006 | 06:17 PM
mountaindewguy's Avatar
Default OBD1/OBD2 Mixmatch!?!??!
im building an lsvtec. i was gonna do all OBD2, use my civic engine harness (vtec), and obd1 ECU w/ conversion harness, and thats that.
BUT
i may get a deal on a obd1 GSR head. if i were to use that with my OBD2 block, what would i run into? or would i just use my civic engine harness (from obd1) and obd1 ECU and thats it? or is anything special required? thanks!
Old Mar 16, 2006 | 06:25 PM
b18ccivics's Avatar
what year car is it going in?
Old Mar 16, 2006 | 09:19 PM
Default Re: (b18ccivics)
95 ex civic - obd1
will be using a p28 obd1 ecu from phearable.net
Old Mar 17, 2006 | 12:49 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (mountaindewguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mountaindewguy &raquo;</TD></TR><TR><TD CLASS="quote">95 ex civic - obd1
will be using a p28 obd1 ecu from phearable.net</TD></TR></TABLE>
You were putting this into an OBDI car and you were going to try to make it OBD2?
You're over-complicating. Use an OBD1 engine harness and a OBD1 ECU. There will be one plug you will not use, which will be near the crank pully.
Old Mar 17, 2006 | 01:24 PM
Default Re: (JDM_Ej)
i was going to use an OBD2 setup (head and block) With the OBD1 p28 ecu, and the conversion harness - basic setup
what i was saying is, if i use and OBD1 gsr head instead of OBD2, what will be different besides not needing the conversion harness...?
JdM_Eg6_SiiR
Engine Management and Tuning
Dec 6, 2010 07:12 AM
nothing_shocking
Dec 1, 2010 04:00 PM
sevenfc
Apr 22, 2009 08:02 PM
tig3rxiong
Jul 7, 2005 08:14 PM
Type RS
Nov 18, 2002 10:09 PM
