GSR Throttle Body Installed on D16Y8 Auto...
I've made my GSR Throttle Body work with my automatic, I had to design a system to work with the Auto IAC. I had to create a few mods, but hey I got my car idling at stock specs, with no irratic idling. The only problem is a CEL, for IAC malfunction, I guess it doesn't understand my design, but it's doing fine, despite the annoyance of the bright yellow light.
The car revs slightly higher about 250RPMS, smoother shifting, and revs faster especially after 4,000RPM.
Modified by InfiniteVTEC at 6:13 PM 3/17/2006
should i say a witty cutdown..... ?
should i ask why?
should i post, "IBTL"?
dude.... you installed a throttle body on your auto and want to 'market' it like youre the nations greatest inventor, but you still have a CEL and didnt post any pictures.
so i'll just post a big.....
<FONT SIZE="13">WTF!?</FONT>
should i ask why?
i dont know bout actual improvements. u just put a CEL on and that makes your car run in limp mode. limp mode is a safe gaurd so things dont get messed up more than it already is, and you lose power this way. but congratulations one removing like what, 6-7bolts, and putting them back in the correct place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lemon_juice »</TD></TR><TR><TD CLASS="quote">i dont know bout actual improvements. u just put a CEL on and that makes your car run in limp mode. limp mode is a safe gaurd so things dont get messed up more than it already is, and you lose power this way. but congratulations one removing like what, 6-7bolts, and putting them back in the correct place. </TD></TR></TABLE>
A.) not all CELs put the car into limp mode
B.) the throttle body is held on by four bolts - or a combination of bolts and nuts that equal four total points of contact
C.) yes, this is worthless, but let him have his 15 minutes and stop shitting on him.
"Automatic performance" for a Civic is like "sexy lingere" on a 70 year old man, if you get my drift.
yes i know not ALL CEL put you in limp mode, but wen it comes to something measuring air and its readings are messed, it will go into limp mode.
yes, 4bolts but then u gotta think of the actual sensors are bolted, and intake piping itself.
perseverance
Nov 27, 2006 03:57 PM
